Off-Set Router Bit Wrench
  • KC7CN
    • Aug 2007
    • 73
    • Deltona, Florida
    • PowerMatic 64A
    This is not what you would call an exciting find, but if you have a router table with a lift, you may be interested in this off-set wrench.
    I didn't buy one when I bought my PRL lift from WoodPeckers. Later, when I decided to bite the bullet and pay the $20 + shipping they no longer carried the product.
    This wrench is a fairly new product for MLCS, and sells for $14.95. A good price considering they have free shipping! They have the standard 1-1/8'' Porter Cable, plus 15/16'', 3/4'' and 7/8'' for other brands.
    http://www.mlcswoodworking.com/shops..._wrench_anchor
    -Don
    • 3128
    I bought those from Sommerfeld for both my router tables and they are some of the biggest time savers in the shop.
    • charliex
      • 632
      • Spring Valley, MN, USA.
      • Sears equivelent BT3100-1
      About a year ago I used a MAPP torch and a vise to modify one of my PC wrenches to use on the Jessem RT. Works great, less time spent cranking it up/down.
      • radhak
        • 3061
        • Miramar, FL
        • Right Tilt 3HP Unisaw
        I like the idea, but don't you need two for the PC routers? I do for my 7518.
        I am thinking I could get a set of the 'thin' wrench sets and bend a couple for my purposes, like this. Ok, I might need to buy two sets, but the rest might be useful for other needs too.
        I like charlie's idea too - could try and bend some I already own. Now to find a heat source .
        - Aristotle
        • KC7CN
          • Aug 2007
          • 73
          • Deltona, Florida
          • PowerMatic 64A
          Originally posted by radhak
          I like the idea, but don't you need two for the PC routers? .
          One should be enough! Use the stock straight wrench for the top location.
          -Don
            • 3128
            I need two for my PC693 which is why my router tables both have Triton routers in them. They have a push button spindle lock and the lock automatically engages if the router is raised to the top.
            The nice thing about the offset wrenches is that I can leave the router set to it's height and change back and forth between cope and pattern bits and never have to reset the router height.
            • Andrew Benedetto
              • 1071
              • SoCal, USA
              Problem with these type of stamped wrenches that they crack, I hate how they flex and slip off collar. Had to weld my delta BT shaper one. As said, better to heat and bend a forged wrench. Unlike saw blades, router bits need to be tightly torqued. I have done that for car applications.
              Andrew
