To be honest -I was tempted with this deal but I did not pull the trigger. Several reviews I found all said the same thing. This is a very specialized single-purpose router. It works great when mounted in a table. In a table it has several advanced features like above table height adjustment, above table bit change, single hand bit change with auto-lock. But everything else about this router gets poor reviews. On/Off siwitch is awkwardly located, plunge base is uncomfortable, moving the motor between bases causes people to hurt their fingers, use of router bushings require extra accessory. In other words if you buy this router you should put it into fixed base, mount into the table and throw away carrying case and plunge base because you will never take this router from the table. $120 for a mid-size router that will live in a table is a regular price in my opinion, not a "you suck" level deal. For $120 I can buy any day a Bosch 1617 fixed base router (in Craftsman colors) new, without any compromises. Bosch is probably the best fixed-based router overall. Less features in the table but great outside the table. For extra $65 I can get the same Bosch router with 3-base kit.
Please note - I don't have this router - info is from online reviews.
