HF Coupon/Sales Question
  • JoeyGee
    • 1509
    • Sylvania, OH, USA.
    I received the latest HF flyer, and it has a coupon for the belt/disc sander for $49.99. Since this is a coupon, and not a "sale price" would I still be a ble to use a 20% off on top of it? I doubt it, but thought I would see if anyone has done it.
    I know the B&D isn't the greatest, but if I can get it for $40, I would be happy.
  • KC7CN
    • Aug 2007
    • 73
    • Deltona, Florida
    • PowerMatic 64A
    Can't say for sure, but knowing Harbor Freight, I would say yes, you could also use the 20% off.
    -Don
    • drillman88
      • Dec 2007
      • 572
      • Southeast
      It depends on the store/manager, sometimes they will take both at my local store. It don't hurt to try though.
      • sweensdv
        • 2873
        • WI
        • Baileigh TS-1040P-50
        They let you use coupons for regular sale items so I see no reason why they wouldn't let you use one for a coupon sale item.
          • 9554
          I've not tried, but a coworker got one of those smaller air compressors that way...
          Even without the 20% off coupon, that is a good price for that sander...
          • Garasaki
            • Sep 2006
            • 550
            I attempted to stack a 20% off (single item) coupon and a 15% off (entire order) over the weekend at my HF and they didn't take it
            "we only accept 1 coupon" they said.
            But that's just my local one. And that's a whole different situation then trying to use one of their price coupons (it might end up showing up as the coupon price on the register anyway!) and the %off coupon.
            Sure don't hurt to try.
            -John
            -Henry Blake
              It's well worth a try. The "coupon" price is sometimes actually a sale price - if you took the item to the register it would ring up at the coupon price.
                Asked this question of one of my local HF managers not long ago. He says that they are not supposed to stack. This is the reason HF is going more and more to coupons... they want control of the bottom line cost. He says the computers are supposed to be set up to move the 20% discount to the highest-priced non-coupon item (sale prices are OK). If there is only the one item, and it's rung with a coupon, it won't take the second coupon on top. That said, he also said that perhaps not all the computers are set up this way, and that the managers have the authority to override any price, so it doesn't hurt to ask for the extra discount.
                • tjr
                  • Oct 2008
                  • 167
                  • at the falls of the Ohio
                  • BT3000 (1 3/4 of them)
                  At the closest store, their registers are set up even stranger than what Uncle Cracker describes - if it rings up any specific item coupons, it won't accept the 20% off any item even on items that didn't have a coupon. So, they have to ring 2 transactions - one for all the specific item coupons and one for all the rest of the stuff where it does the 20% off any item on the most expensive one.
                  • stormdog74
                    • Mar 2007
                    • 426
                    • Sacramento, CA
                    This is how the HF near me works too. I would have them do a price check on it as what JR says is often true, although not always.
                    • AlanWS
                      • 257
                      • Shorewood, WI.
                      It's worth checking several different prices. Sometimes the price in the store is as low or lower than a coupon price anyway. Sometimes the web price is lower, and if you print out a list they will give you that price. As it's not a sale, but only a different HF price, you could get a coupon discount from that. And of course print ads and catalogs also have different prices, that could be higher or lower than any of the others.
                      Alan
                      • tsbrewers
                        • 207
                        Same as ours. If you have a 20% coupon, you have to ring that up seperately from everything else.
                        also both of ours will not stack a %off coupon with a merchandise coupon.
                        Brew
                        • garymuto
                          • Aug 2007
                          • 194
                          • Encinitas, CA
                          • Delta Cabinet Saw
                          My HF store had to ring up a 20% off coupon purchase separate from other items that I had coupons for specifically. I know before 2009 they had no problem taking another coupon but the policy changed. Good luck at your store and let us know how you make out.
