Grizzly 2HP Dust Collector - $125
  • b75025
    • 66
    • McKinney, TX
    Not mine - -
    http://dallas.craigslist.org/ftw/tls/1289946782.html
    "I see", said the blind man, so he picked up his hammer and saw.
    Not a bad price, but anything larger than 1-micron will leave you coughing and dusting in your shop. Better figure in the cost of a couple new bags or a canister unit.
      • 9503
      Consider a Wynn paper cartridge at $103.00, that would make the rig $228.00. Is that too much?
      For me the big drawback is the 220V. None of that in my shop yet.
        Sounds like a reasonable price to me. I'm not certain, but some 220V tools can be modded to 120V, but a real 2HP at 220V is a pretty stout load. Not all standard circuits could accommodate it, particularly if wire runs are longish.
        • Knottscott
          • 3815
          • Rochester, NY.
          • 2008 Shop Fox W1677
          The G1029 is the DC unit I've been running for the past 7 years or so. It's a workhorse and a great basic unit with a stout motor and a larger impeller. Three of my friends have the same unit...some of which really have some miles on them without issue. I've added a JDS cannister to it and use 6" mains. The amp load is in the range of 20-26 amps at 120v, but is convertible to 240v which makes it about half that.
          I think I paid $240 (+ tax) directly from the Muncy store.
          • toolguy1000
            • Mar 2009
            • 1142
            • westchester cnty, ny
            dbhost...can you post a link to the paper cannister filter you mentioned above? thanks.
            • jgscott987
              • 287
              • Greensboro, NC, USA.
              • BT3100 +
              2 HP on a 110v circuit would be doable, but you'd need a dedicated circuit...
              2 HP = ~1500 watts = ~14 amps at 110 volts (~7 amps at 220 volts).
              Most 110v circuits are rated at 15 amps-- pretty rarely they go up to 20 amps.
              I don't know anything about converting a 220v motor to 110v. I have the opposite problem- several 220v outlets and nothing to plug in to them!
