20% Off @ HF 5/22-5/25
  • drillman88
    • Dec 2007
    • 572
    • Southeast
    http://www.harborfreightusa.com/usa/...9&keycode=0000
    • 9533
    The mortising machine is marked down to $124.99 on the current circular, minus that 20% or $25.00 that brings it down to $100.00
    Awfully tempting....
    • jeepjohn
      • Mar 2009
      • 38
      • Magnolia, TX
      • Bought a BT3100 and looking to put some nice projects together
      I noticed that the 20% off coupon states that it is good from 6/11-6/17. What gives? Be careful about showing up to the store with the coupon... I'm wondering if they know this and will honor it anyway?
      I don't see a mortising machine in the circular. When did you get the circular you are referring to?
        • 9533
        Click on See Our Current Ad.
        Page 21, lower right hand corner, right above the band saw...
        Expires 5/26/2009.
        BTW, coupon states valid from 5/22/09 - 5/25/09
        • jeepjohn
          • Mar 2009
          • 38
          • Magnolia, TX
          Here is what I saw on the coupon...
            • 9533
            Huh, that's not what comes up for me...
            Maybe this will help...
            Printable Link.
            • jeepjohn
              • Mar 2009
              • 38
              • Magnolia, TX
              DB-
              Look at the dates below the "20% off"... that's what I'm referring to. It is different on the actual coupon than the ad title.
              • Sam Conder
                Woodworker Once More
                • 2502
                • Midway, KY
                • Delta 36-725T2
                Originally posted by jeepjohn
                DB-
                What DB is trying to tell you is that something is "wonky" with what you are seeing. When I visit the link that the OP posted, this is what I see..
                Sam Conder
                BT3Central's First Member
                • jeepjohn
                  • Mar 2009
                  • 38
                  • Magnolia, TX
                  I realize that, but even the coupon he posted has the same dates as the one I'm seein' on my computer. Yours, on the other hand, has the correct dates.
                    • 9533
                    The pic sam posted is what I see.
                    Try clearing your cache and go at it again... Something is goofy in your browser session pulling up something cached you should have had in the first place...
                    Sorry, whipped tired today...
                    • Sam Conder
                      • 2502
                      • Midway, KY
                      • Delta 36-725T2
                      Yeahbut the problem is on your end... the one he posted looks fine to me as does the original. Mine is a screen capture of what I see therefore explain's it's "correctness" for you. Check your PC's date and time as well as the time zone, you might find the error. Also, try clearing your browser cache, history and then trying again.
                      Sam Conder
                      • jeepjohn
                        • Mar 2009
                        • 38
                        • Magnolia, TX
                        I cleared my browser cache, history, and checked everything to no avail but our internet access for the company is through a proxy server so that is most likely the issue. I'll just have to do this at the house.
                        • kramer katt
                          • 375
                          • SO CAL, USA
                          • BT3100 and Craftsman 100
                          HF coupons
                          IF your worried about the coupon dates try this one good 2/13 to 5/31
                          Attachment failed Could not get pdf less than 68 kb
                          Anyway this coupon is very available at Fatwallet or SlickDeals
                          --Albert Einstein
