OC CL: Enco (?) 14in BS, $75
    Found this surfing CL tonight. Not much info, but appears well maintained.
    http://orangecounty.craigslist.org/tls/1164457312.html
  • GrantV
    • Aug 2007
    • 85
    • Orange County, California
    would rather have this 24" SCMI bandsaw for $1300 asking. Which means you could probably get it for less.
    http://orangecounty.craigslist.org/tls/1140415635.html
    • Tom Slick
      • 2913
      • Paso Robles, Calif, USA.
      • sears BT3 clone
      That would be a deal for the SCMI! the only problem is SCMI machines are difficult to get parts for after they get to be about 5 years old.
      • GrantV
        • Aug 2007
        • 85
        You can get Bearing and Tires for those saws. Other than that you'd have to break something really.
        https://www.minimax-usa.com/index.ph...d=48&Itemid=58
          • 9545
          Chipped pulley?
          If he / she means wheel, RUN AWAY!
          If he / she means roller bearing guide, no bigge...
          I suspect they are talking about wheel.... I guess it depends on what chipped means. If it is just a tiny nick that can be honed out and the wheel rebalanced....
          Just looked it up. Enco 199-9001 14" wood cutting band saw.
          This saw is rated at 1/2 HP, and this particular model appears to be well out of production, and support by the vendor. From what I can figure out from the manual, the saw is built by Shent Tsai in Taiwan, and it appears to be a stripped version of the HF 14" band saw (as if stripping it down further were possible). I rarely say this.... But save your money and wait until you can at least afford a Harbor Freight band saw... That is a cheap saw to begin with, and it has problems...
