80-piece Neiko 1/2" 2 & 3-blade Router Bit Set -- $99
  • footprintsinconc
    • 1759
    • Roseville (Sacramento), CA
    its on amazon, at this link.
    80 pieces, 1/2" shank! as a startup set is not a bad deal. i dont know about Neiko brand, but i bought my 30 piece set from costco for like $70 and they were 1/4" shank.
    its free shipping with amazon prime.
    omar
  • jhgrady
    • 297
    • Alexandria, Va, USA.
    footprintsinconc,
    Couldn't pass it up, thanks.
    John
      • 9523
      Holy cheeze whiz Batman!
      Retail on my Skil 30 pc 1/4" shank set is the same as that... Now if only the MLCS 66pc 1/2" shank set would get that low...
      • Alex Franke
        • Feb 2007
        • 2641
        • Chapel Hill, NC
        Here's the link that gives referral credit back to BT3Central... Looks like other buying options have it for $10 less, but then there's shipping you have to add...
        80-piece High Quality 1/2" 2 & 3-blade Tungsten Carbide Router Bit Set
        New: $89.95 (25% savings)
        Used: Not available used
        Rating: 4.0 of 5, 16 review(s)
        • footprintsinconc
          • 1759
          alex,
          when i originally post the link, i wanted to do that credit thing, but couldnt get anything on the search.
          i know you explained it once before, how do you do that so bt3 get some credit?
          thanks!
          omar
          • Alex Franke
            • Feb 2007
            • 2641
            • Chapel Hill, NC
            If I hadn't just spend a zillion dollars at Holbren's router bit blow-out a while back, I'd be all over this one.
            alex,
            thanks!
            Oh, just click the "link generator" link in my signature (sometimes it takes a sec to load), add the amazon product ID (10 characters and often starts with "B"), select an image size, etc. Copy/paste the BBCode result into your post. Let me know if you have any problems with it!
            • footprintsinconc
              • 1759
              thanks alex, i will try it out!
              omar
              • southernbob
                • Jan 2008
                • 42
                • South Florida
                what you get with 50 and 80 piece sets
                Product Description
                NEIKO USA 50pc Tungsten Carbide 1/2" Router Bit Set
                Three-blade:
                straight: 1/2, 5/8 and 3/4";
                flush-trim: 1/2" x 1";
                slot-cutter: 1/4, 5/16, 3/8 and 1/2".
                Two-blade:
                Double Roman: R1/8, R3/16 and R1/4;
                flush trim: 3/8" x 1/2", 3/8" x 1", 1/2" x 1/2", 3/4";
                45-degree chamfer: 3/8, 1/2, 5/8 and 3/4";
                corner round: R1/4, R3/8 and R1/2";
                beading: R1/4, R3/8 and R1/2";
                cove: R1/4, R3/8 and R1/2";
                Roman Ogee: R5/32, R7/32 and R9/32";
                panelling: R1/4 and R3/8";
                Ogee flute: R3/16";
                classical cove: R5/16";
                wave-edge: R3/16";
                classical: R3/16" and R1/4";
                straight: 3/16, 1/4, 5/16 and 3/8";
                dovetail: 1/2 and 9/16";
                cove-box: R1/8, R3/16 and R1/4";
                panel-pilot: 1/4";
                V-grooving: 3/8 and 1/2".
                Product Description
                NEIKO USA 80pc Tungsten Carbide 1/2"Router Bit Set
                Ten three-blade router bits:
                straight: 1/2, 5/8, 3/4 and 1";
                flush trim: 1/2, 1/2 x 1";
                slot cutter: 1/4, 3/8, 5/16 and 1/2".
                70 two-blade bits:
                25 degree trimming: 1/2";
                30 degree trimming: 1/2";
                flush trim: 3/8", 3/8" x 1";
                Corner round: 1/8, 3/16, 1/4, 5/16, 3/8, 1/2, 5/8, 3/4" and 1";
                cove: 1/8, 3/16, 1/4, 5/16, 3/8 and 1/2";
                beading: 1/4, 3/8, 5/8, 3/4 and 1";
                Roman ogee: 5/16, 1/2;
                Classical cove: 1/2";
                Classical: 3/8 and 1/2" ;
                Ogee flute: R3/16";
                Double Roman: 1/4 and 5/8";
                wave edge: 5/16";
                60 degree horse-nose: 5/8;
                Rabbeting: 3/8";
                45 degree chamfer: 1/2";
                30 degree chamfer: 5/8";
                22.5 degree chamfer: 3/4";
                15 degree chamfer: 7/8";
                cove box: 1/4, 3/8, 1/2 and 5/8";
                V-grooving: 1/4, 3/8, 1/2 and 5/8";
                round nose: 1/4, 1/8 and 1/2";
                dovetail: 1/4, 3/8, 1/2, 5/8 and 3/4";
                panel pilot: 3/8"; keyhole: 3/8";
                cleaning-bottom: 3/4";
                60 degree V-grooving: 5/8";
                straight: 3/16, 1/4, 5/32, 5/16, 3/8 and 7/16";
                bottom : 1/2, 5/8 and 3/4";
                Classical plunge: 3/4";
                bowl tray: 1"
                • axa
                  • Mar 2007
                  • 98
                  Use?
                  Do those who buy these mass sets, actually end up using most of these bits?
                  My observation is not...
                  • Knottscott
                    • 3815
                    • Rochester, NY.
                    • 2008 Shop Fox W1677
                    I'd hazard a guess that the vast majority don't use them all, but the price is attractive and at least this big set only costs about the same as most smaller sets. The quality is largely an unknown though.
                    • dkerfoot
                      • 1094
                      • Holland, Michigan
                      That is actually part of the beauty. You now have nearly every router bit you will ever need, so when you are in the middle of a project and realize you need a specific bit, you don't have to wait for mail order or pay big bucks at the local store.
                      Then, when you wear a handful of these out, you now know which Whiteside bits to buy from Holbren!
                      To me, a worn out cheap tool is a happy thing, but a high quality tool that gathers dust is a tragedy.
                      Doug Kerfoot
                      KeyLlama.com
