Home Depot Deals
  • 10sCoachRick
    • 134
    • Austin, TX
    If you are in the market for 'cheaper' tools, check in the tool crib for the Work Force brand small power tools, specifically, the jig saw, angle grinder and corded VSR drill...all $10 at our local Depot. Not exactly Bosch but not bad if your tools tend to walk away.
    • 10sCoachRick
      • 134
      • Austin, TX
      If you are in the market for CF bulbs, check out the lighting dept at your local HD...ours had select fourpacks of EnVision(sp?) CFLs at two dollars and change. I have quite a stock of the spiral bulbs so I didn't buy any...the reflector lamps I need were not on sale . YMMV and all that.
      Did pick up one of the $10 angle grinders I mentioned earlier...trying it out this weekend.
      • 10sCoachRick
        • 134
        • Austin, TX
        OOPs, never mind
        Last edited by 10sCoachRick; 07-24-2008, 09:39 PM. Reason: So fast, I typed something I hadn't thought of yet!
        • THyman
          • 315
          • Atlanta, Georgia, USA
          Bosch Jigsaw and ROS combo pack
          I also found the Bosch Jigsaw 1587 with one of the free new 5" ROS with the 1 micron filter in the clearance area for $104. Not sure if the ROS was variable speed or not but i think this is a pretty good deal especially if you need a jigsaw.
          War Eagle!
