25% HF coupon
  • Knollskid
    • 14
    25% HF coupon
    Is there still such a thing out there? all I can find is the 10%
    Thanks
    KR
  • sweensdv
    • 2873
    • WI
    • Baileigh TS-1040P-50
    I don't recall ever seeing a HF 25% coupon. 10%, 15% and I think 20% but never 25%. Then again, I could be wrong.
      I used a 25% coupon once, but I don't think they honor then any longer (could be wrong).
      • ari_c
        • Jun 2004
        • 15
        • Centreville, VA, USA.
        I used the 25% once and around the same time there was a 30% which I used way way too many times! Boy the good ole days......
        • Knollskid
          • 14
          so is 10% it right now?
          • ari_c
            • Jun 2004
            • 15
            As far as I know. The 15% Percent off Coupons on a single item are pretty scarce from HF these days, I haven't see one for quite some time. They've basically replaced them with the weekly product coupons instead.
            • theminor
              • 119
              • Dalton, GA
              Every now and then they'll put out a 10% coupon and possibly a 15%, but I haven't seen one for more than 15% in quite some time. They used to regularly have 20% off coupons (some didn't even have expiration dates) and even some 30% off coupons that you could just print out as many times as you wanted. But those days are no more!
              My Site
              • gjat
                • 686
                • Valrico (Tampa), Florida.
                Did a google search "harbor freight coupon" and hit on this 25% off:
                http://i.slickdeals.net/attachment.p...4&d=1172709920
                20% off http://www.tractorbynet.com/forums/a...n-coup_top.jpg
                  Your slickdeals link is a dead end (there is one here for 10% off the entire purchase), and the other one is a tractor company...
                  • Knottscott
                    • 3815
                    • Rochester, NY.
                    • 2008 Shop Fox W1677
                    It's possible that the bigger % off coupons were counterfeits that they use to accept, but no longer do. I haven't seen much over 15% lately. The last time I had a 20% or larger coupon, I was buying sandpaper so I gave it to the guy in front of me and saved him $30 vs my $0.47.
                    • aussieblake
                      • Aug 2007
                      • 34
                      • OKC
                      • Unisaw
                      At one time, there were two coupons floating around 25% and 30% off. I used the 30% a few times. Some received the coupon in the weekly mailer and scanned it in. It worked by the cashier inputting the coupon code and did not require a managers override. Lots of people used it, after that coupons have been kind of scarce.
                      aussieblake
                        HF has been weaning us off the percent-off coupons, in favor of individual coupons on those items they select.
                        • ari_c
                          • Jun 2004
                          • 15
                          The 30% off was not a counterfit. It was from a paper somewhere in the midwest. The coupon was in their system and actually scanned in. Some employees were upset that the coupon was larger than their employee discount.
                          I might add that there has never been a 30% off since!
                          • Santa Clarita Len
                            • 166
                            • Santa Clarita Calif.
                            • Bt3000 and Dewalt radial arm saw
                            Try Googling "Harbor Freight Coupons", I recently found some as high as 20% discount with no experation date and I know that some stores won't honor the coupons with no expiration date so make friends with the manager.
