Wixey Angle Gauge
  • sweensdv
    • 2873
    • WI
    • Baileigh TS-1040P-50
    Wixey Angle Gauge
    Normally $39 on sale at Hartville for $29.00. http://www.hartvilletool.com/product/12456
  • Jeffrey Schronce
    • 3822
    • York, PA, USA.
    • 22124
    Great product guys. I use mine all the time on TS, BS and CMS.
    • agent511
      • Jun 2005
      • 257
      • Philadelphia
      • TS3650
      great product. Available from the manufacturer 24/7 for $39.99 with free shipping, so if you miss this deal, you can get it for almost the same deal at your leisure.
      http://www.wixey.com/anglegauge/buy/index.html
      darksider
      • cobob
        • 252
        • Rolla, MO, USA.
        Is this just for vertical angles, or can it be used horizontally, for instance, with the sliding mitre table?
          Won't work in the horizontal plane, must be in the vertical plane.
          For example, you can set your blade bevel angle (blade tilt from the vertical)
          but you can't use it to measure the miter angle.
          • eccentrictinkerer
            • Aug 2007
            • 669
            • Minneapolis, MN
            • BT-3000, 21829
            FWIW,Rockler carries this item $39.99 and has a 20% off coupon this weekend.
