Unisaw on Austin Craigslist
    Posted yesterday, found ad this this morning. At that price it may be gone by now. (Would be if I had room for it now!) There is a # posted so it's easy to check out.
    http://austin.craigslist.org/for/440952958.html
  • Powercat80
    • Sep 2007
    • 45
    • Austin, TX
    Pappy
    I sent you a PM
    • GrantV
      • Aug 2007
      • 85
      • Orange County, California
      at that price I'd be worried about a cracked left rear trunnion support or something like that. Look it over closely.
        Originally posted by Powercat80
        I sent you a PM
        Let us know how it comes out.
        • Powercat80
          • Sep 2007
          • 45
          • Austin, TX
          I bought it!!
          Well Pappy, I bought the saw. I'm ecstatic!!
          Here's what I got: A Delta Unisaw model 34-802, 2 phase 220V, 3hp motor. (Which is fine with me as I have 220 in the garage.) I need to check the serial with Delta, but I'm guessing 15-25 years old, but in excellant condition. The picture showed surface rust on the table, but a little emery paper and steel wool cleaned it up. Not pits on the surface. It came with a Delta mobile base, a micro adjust fence, and about 15 commercial and custom made jigs. Some of which I may need to post pictures because I haven't quite figured out what they do. Based on the story, and I confirmed it was used by an avid hobbyist here in Austin. No production use. The lift and arbor was a little tight at first as it has been setting for a couple of years, but a little Tri-Flow and WD-40 freed everything and now they work smooth as silk. Motor is very strong with no hesitation or vibration. Trunion looks new.
          Best of all I gave $275 cash! I think it's a good deal. Like I said, I'm ecstatic!
          • coach
            • 317
            • Forney, TX.
            • Powermatic 66
            Congrats.
            Check that motor again. There is no 2 phase. Only 1 and 3. If it is single phase, it will run on standard household 220. If it is three phase, you'll likely have to get a phase converter.
            If you're not living on the edge, you're taking up too much space.
            • Powercat80
              • Sep 2007
              • 45
              • Austin, TX
              My mistake
              You're correct, single phase. Works on my standard 220 outlet. Just typing too fast.
              • ragswl4
                • 1559
                • Winchester, Ca
                • C-Man 22114
                Great Deal! Should be the last saw you'll ever need to buy.
                RAGS
                Raggy and Me in San Felipe
                sigpic
                  man, worthy of a gloat.
                    I do believe....
                    "You owe me, big time!
                    • Powercat80
                      • Sep 2007
                      • 45
                      • Austin, TX
                      Yes! Yes I do!
                      I had seen this add on CL but didn't do anything until I got your input. Thanks for all the advise.
