JET Remote Control for 115V DCs, $35
  • thrytis
    • 552
    • Concord, NC, USA.
    • Delta Unisaw
    Amazon has the Jet 708650 Remote Control Unit For 115 Volt Dust Collectors on sale for $35. Kind of lacking in technical details, but not a bad price for a remote control.
    Eric
  • kenh
    • Jul 2007
    • 11
    JET remot control
    Hi,
    Does anybody know if the unit comes with a remote controller?
    Thanks!
    Ken
    • Jeffrey Schronce
      • 3822
      • York, PA, USA.
      • 22124
      Originally posted by kenh
      Hi,
      Thanks!
      Ken
      BEst I can tell, from Jet parts website, it would be included.
      • ragswl4
        • 1559
        • Winchester, Ca
        • C-Man 22114
        Kind of curious that on the same page Amazon shows this together with the Jet switch:http://www.amazon.com/PSI-Woodworkin...618766-3707359
        Makes me wonder if it really does come with a remote control?
        RAGS
        Raggy and Me in San Felipe
        sigpic
        • thrytis
          • 552
          • Concord, NC, USA.
          • Delta Unisaw
          I saw that and thought it was an odd combination. Even if the remote was sold separately, why would you buy the Long Ranger switch? The only thing the Jet remote would be useful for in that case is the timer.
          Eric
          • thallikar
            • May 2006
            • 199
            Ordered it an hour ago. The description says ". Has the remote with the on/off and a timer to set unit from 1 up to 99 minutes of operation."
            So, hoping otherwise I will return and get the PSI one.
            • Almightymoonpie
              • Jun 2007
              • 31
              • Mobile, Al
              Got the unit in during Lunch, and it has a remote. The remote will turn the unit on/off and has a timer function, Installed it this afternoon and works great with my HFDC
              • Dale In Corona
                • Jan 2005
                • 81
                • Corona, CA, USA.
                Will have to keep looking... or break down and go X10...
                "Availability: Currently unavailable. We don't know when or if this item will be back in stock."
                • kenh
                  • Jul 2007
                  • 11
                  Controller, not working????
                  Hi,
                  I got mine today but when I turn on the switch with my Delta DC connected, it trips the breaker out, even with 20amp outlet. Did anybody have similar experience? Defective unit?? I contacted Amazon but they do not have any in inventory so they cannot replace it. I would like to keep it if there is a way to fix the problem. Can anybody help me?
                  Thanks!!
                  Ken
                    • 22109
                    Hi,
                    Thanks!!
                    Ken
                    The first thing to do is to see if it's load related... or if the switch itself is presenting a short to your AC outlet.
                    Try plugging a 100W lamp into the remote switch and see if the breaker still pops. This will tell you if the switch works or has a gross internal short.
                    Does the DC plugged into the wall itself blow the breaker when you turn on the DC? I wouldn't think the extra load of the switch should trip the breaker if the DC by itself does not.
                    • kenh
                      • Jul 2007
                      • 11
                      Still trips breaker...
                      I tested the unit with a small light connected or without anything connected. It tripped breaker in either way. Seems like a defective unit. It's a pity. It is a well-built unit if it works.
                      Ken
                        • 22109
                        Ken
                        yeah, definately defective unit, then.
                        • Woodwerker
                          • 490
                          Got my controller today. Very Nice heavy duty and works great. It going to make my life a lot easier...
                          Every tool you own is broken, you just don't know it yet :-)
                          • GrantV
                            • Aug 2007
                            • 85
                            • Orange County, California
                            You might open it up and see if anything is shorting out inside. Or maybe they got a wire swapped. Are you good at using a meter? Did you get a wiring schematic with the unit?
                            Ken
                            • kenh
                              • Jul 2007
                              • 11
                              Unfortunately, the unit did not come with a wiring shematic. I will open it and check if there is an obvious problem that is causing the short circuit. If it is not really obvious, fixing the unit would be beyond my ability.
                              Will be busy today and tomorrow so I gonna try it on Sunday afternoon.
                              Thank you for your suggestion.
                              Ken
