Freud TK206 24T Rip Blade from AMZ for $20 shipped
  • Knottscott
    • 3815
    • Rochester, NY.
    • 2008 Shop Fox W1677
    Everyone's TS benefits from a decent rip blade now and then. This one is now part of Freud's "Avanti" series. $20 after 20% automatic discount at checkout. You'll need to add an item worth $0.01 to get free s/h.
    Product Promotions
    Save an extra 20% on saw blades offered by Amazon.com when you purchase 1 or more
    Freud TK206 10-Inch 24 Tooth ATB Thin Kerf Ripping Saw Blade with 5/8-Inch Arbor
    Technical Details
    • Excellent for framing
    • Expansion slots cut vibration
    • Anti-kickback
    • Thin kerf, flat tooth, long life
    • 10 inch 24tip, 5/8 inch arbor
    Product Description
    Amazon.com Product Description
    The Freud 10-Inch 24-Tooth Thin Kerf Framing Rip Saw Blade features carbide tips for a precise cut and a thin kerf for less power consumption. For easy use and added precision, the blades also feature an anti-kickback design, and tri-metal brazing for impact resistance. The blade has expansion slots that are strategically placed to allow for blade-body expansion from centrifugal force, and thermal expansion during actual use. The slots are used to prevent air turbulence and eliminate vibration as well. The blade comes with a limited lifetime manufacturer's warranty and features a 5/8-inch arbor.
    Product Description
    10" x 24 Tooth, Alternate Top Bevel, Thin Kerf, Carbide Tipped Rip Blade.
    • 22029
    that's a good value and a practical ripping blade for a saw like the BT3x. If you're going to rip more than a couple of boards you might do well to take advantage of this. I think they're regularly around $25 to 30 bucks, street prices.
