Bosch 7-1/4-Inch 24 Tooth ATB Saw Blade, 5 pack w/free football $24.43
What are these 24 tooth circular saw blades good for?What if there is no tomorrow?....there wasn't one today!
-BarryComment
From the Product Description on Amazon.com
"Product Description
Amazon.com Review
This fun, functional promo pack from Bosch includes eight 7-1/4-inch circular saw blades bundled together with a football. Embossed with the Bosch logo and stitched with regulation lacing, the football is the grown-up version of a prize in a cereal box.
But while the football is made for play, the saw blades are all business. Their diamond-ground C-3 Dyanite carbide teeth retain a super-sharp edge from start to finish -- holding their edge up to five times longer than standard carbide blades. These outstanding teeth boast tri-metal shim brazing for added impact resistance, and a fully hardened thin kerf plate. The blade itself has an ultra hard body that keeps its accuracy cut after cut. The whole package is treated with a blue anti-friction coating that increases your cut speeds and reduces heat. All together, it adds up to an impressive performance.
These blades are 7-1/4 inches/24-tooth, with a 5/8-inch arbor. Use these blades for a wide variety of circular saw applications. They cut soft woods, hard woods, plastics, and more -- even dimensional or engineered lumber. "
My guess would be that they are good for rough cutting of lumber not for smooth crosscuts and not for ripping sheet goods without some tear out. Just a guess, I don't own these blades.Last edited by ragswl4; 09-02-2007, 11:53 AM.
RAGS
Raggy and Me in San Felipe
sigpic
The description in the link says "8 pack", making it a nicer deal!Happiness is sort of like wetting your pants....everyone can see it, but only you can feel the warmth.
Mine too! These should make for an inexpensive rip blade, though with limited height. I'll have to try one...you might even get a glueable edge from it.
Edit: Tried one on my TS a while ago. They cut ok...not quite as clean as my Leitz or DW rip blades, but likely glueable as is. Crosscut wasn't even too bad....better than I would have thought. Fine for non-critical cuts, saving your good blade, cutting suspect wood, etc.Last edited by Knottscott; 09-08-2007, 10:54 AM.Happiness is sort of like wetting your pants....everyone can see it, but only you can feel the warmth.
I know these blades are $10 each in the store, for a 10 pack $58 isn't too bad. Although hard to swallow if you missed the $25 deal. They are really nice blades, and paired with the Bosch C20 ($85 in another thread) they do a terrific job.Comment
