HF Mortiser surprise
  • eddy merckx
    • 359
    • Western WA
    • Shop Fox Cabinet
    I decided to pony up the $80.00 for a HF hollow chisel mortiser. That is sale price of $99 plus the no-date 20% off coupon. The surprise was that it comes with tapered extension and extra chuck so you can use it as a little drill press. There is no mention of the extra chuck in the owner's manual and I haven't heard anyone mention it yet, so maybe it's a new feature. I'm thinking it would be a good place for a sanding drum to live.
    This mortiser is black instead of the usual green, but otherwise exactly the same.
    BTW, they have the 4" XY vice for $29.99. I got one to use with the mortiser. I first tried cutting mortises with the stock hold down and it is really marginal. Work beautifully with the XY vice though.
    Now I'm wondering if you could chuck a spiral router bit in the extension and have a sort of wood milling machine. Just a thought, as the speed might be too slow or it might be too flexy.
    Eddy
    • 22106
    if its a regular chuck that fits on a taper, they don't liek to have a lot of side load like a milling machine might put on it.
    The chuck might fall off.
    • eddy merckx
      • 359
      • Western WA
      • Shop Fox Cabinet
      That's exactly what it is Loring. I kind of doubt if it would work also. The extension is around 4" long, so there would be a lot of leverage. Will probably still try it some day if I ever get a spiral bit.
      Eddy
      • messmaker
        • 1495
        • RICHMOND, KY, USA.
        • Ridgid 2424
        What modifications did you do to install the x-y vise?
        • eddy merckx
          • 359
          • Western WA
          • Shop Fox Cabinet
          Messmaker, I used the design frome this link. Note that you will probably want to disassemble the vice and reassemble it so the hand screws point out. I had to drill and tap a couple of holes in the body of my vice to accept the stop plate. It was pretty easy since the metal is quite soft. I used a 6 x 1 metric tap because it matched the bolts(and it was the only size I have). I think anything close would be OK though.
          BTW there was a thread about doing this about a month ago.
          Eddy
          http://www.woodshopphotos.com/main.php?g2_itemId=2480&
          • Jeffrey Schronce
            • 3822
            • York, PA, USA.
            • 22124
            General question here, are chucks normally friction fitted?
            • Thom2
              • 1786
              • Stevens, PA, USA.
              • Craftsman 22124
              yes
              (more characters to make the software happy)
              • Jeffrey Schronce
                • 3822
                • York, PA, USA.
                • 22124
                Originally posted by Thom2
                yes
                Thanks. I have YC mortiser and the chuck fell out when I took it out the box. By design it seemed to be friction fitted however there seemed to be some form of thread in the middle where a screw could go. It's working fine, I just want to make sure it stays that way.
                • eddy merckx
                  • 359
                  • Western WA
                  • Shop Fox Cabinet
                  Here's a link which actually works to see an xy vice on a mortiser.
                  • kleefully
                    • Apr 2004
                    • 36
                    • Tampa, Florida.
                    Tapered extension and extra chuck fits in HF Lathe
                    The great thing about that extra check is that it fits into the HF "36" lathe and you can do horizontial (sp) boring.
                    • Andrew Benedetto
                      • 1071
                      • SoCal, USA
                      Is the x/y vise on sale?
                      Andrew
                      • kramer katt
                        • 375
                        • SO CAL, USA
                        • BT3100 and Craftsman 100
                        Sears has a small note at the bottom of page 3 of the current CC flyer (20% off all craftsman vices)
                        Somewhat a step up in price but also quality,
                        The have several XY machinists vices in their 180 page annual tool catalog.
                        pg 110. The small 3''x3'' is $80 reg price.
                        Also Palmgren sell quite a few on Amazon
                        kk
                        --Albert Einstein
                        • eddy merckx
                          • 359
                          • Western WA
                          • Shop Fox Cabinet
                          Hey Andrew
                          Yes, the 4" xy vice is on sale all month for $29.99. I think that's only $10 off, but still has to be the best deal out there. For that kind of money, you don't mind drilling a few holes.
                          Eddy
                          • Andrew Benedetto
                            • 1071
                            • SoCal, USA
                            I see it in the ad listing. Thanks
                            Andrew
                            • Uncle Hook
                              • 314
                              Is the HF Mortiser now on sale for $100.00 in Retail stores? If so when does the sale end?
                              I don't see it listed in the sale brochures I have.
