Craftsman Router Kit (11.0 amp, Soft Start, 12000-25000 RPM Variable Speed Motor, Fixed Base Included, Plunge Base Included, 2.0 hp, Spindle Lock, 3 LED Task Lights) --$109
What am I missing here? Granted it's a 1/4 hp less than the more desireable 2 1/4 kits but c'mon. Seems like an awful lot for the price. Not for nothing, but - to me- the motor housing looks a lot like the Bosch's and the plunge base - with those booties- reminds me of the Skil .
http://www.sears.com/sr/javasr/produ...cemldffidfmg.0
"Variable speed, heavy-duty, permanently lubricated 100 percent ball bearing motor delivers 12,000-25,000 rpm. Soft start permits the motor rpm to slowly increase to the desired speed setting. Three integrated work lights clearly illuminate the work surface. Die-cast aluminum motor housing adds strength while limiting and reducing vibration. Choose either the standard fixed base or dual-arm plunge base with depth gauge, turret stop and machined arms for smooth up/downward motion which plunges up to 2-3/16 inches. Each base features large, clear, 6-11/16 in. sub-base with square edge on the plunge. Oversized debris shield and vacuum shield provide a clear sightline to the bit. Spindle lock allows for easy bit exchanges. Live tool indicator lights up when power connected. Router includes 1/4 iin. and 1/2 in. collets, edge guide, bit wrench, operators manual and storage case. Wt. 9.5 lbs."
Catalog/Online Exclusive
