Brass Set Up Bars--Rockler
    I have two sets of Whiteside's brass setup bars; one set lives at the router table, the other near my BT. They're some of the most-used "tools" in my shop. This Rockler set includes an extra size that mine don't have, and the price is right.
    Hey Stan, aren't those Sure-Foot clamps NICE? I'm not a huge fan of most Rockler stuff but those things are a home run.
    • Luckbox
      • 371
      • Holly Springs, NC
      Thanks for the info just order a set.
      I love lamp.
      • LYU370
        • Mar 2005
        • 215
        • Streamwood, IL.
        Sounds like I'll be stopping off to pick up a set on the way home.
        Thanks.
        Andy
        • Stormbringer
          • 1387
          • Floral Park, NY
          • Bosch 4000
          Originally posted by Deadhead
          I don't see where to put that code in.
          It asks you if you have any coupons (the line immediately above your first name at the "Bill To:" address entry) when checking out.
          Greg
          • Deadhead
            • 490
            • Maidens, Virginia, USA.
            Thanks, Greg. It already and some other code filled in so I glossed right over it.
            "Success is gettin' what you want; Happiness is wantin' what you get." - Brother Dave Gardner (1926-1983)
            • lcm1947
              • 1490
              • Austin, Texas
              • BT 3100-1
              I've not bought any of these bars before. Been kind of holding off cause I couldn't see the need for them. Without trying to be smart what's wrong with just using a ruler for measuring dado's?
              • ironhat
                • 2553
                Noting wrong at all, lcm. These just make setting the depth of cut quicker and easier.
                Blessings,
                Chiz
                  #23
                  What ironhat said ... it's just a speed and convenience thing. Also, I subscribe to the school of thought that says that while one is in the shop, one should read any kind of tape or rule, or do even the very simplest of arithmetic, as infrequently as possible. The more times you read a measuring stick, the more times you add two or more numbers together, the greater your chances of making a mistake.
                  I find these setup bars to be most useful at the router table. Since the end of the bit is flat, it's an easy matter to grab the proper-sized bar, slap it down on the table, and adjust the lift so that the bit's end is exactly flush with the top of the bar.
                    • 22023
                    Like Larry says, if you're going for standard sized rabbets and dadoes
                    just slap down the proper sized bar and set the height of the blade.bit to match, easier to feel a tiny difference than to check 1/64th on the scale.
                    Try it, you'll like it!
                    BTW, I have steel bars I bought at Lowes for about a buck per 12" piece, you can make several sets for less than 10 bucks. Square bars from 1/8" to 1/2".
                    You say, oh, but they're not brass... the "brass" thing is OK, they are soft and won't damage your blades and bits. But mild steel is still a lot softer than carbide, and I don't whack the bits with the bars- so I don't think that's a big deal.
                      • 2807
                      Thanks for the post, I ordered a set this afternoon.
