Peachtree Woodworking RB Set
    Peachtree is a fine company to deal with, this set I have not used. This is copied and pasted from their email ad.
    ken
    6 Piece 1/4" Shank
    Carbide Rabbetting and Straight Router Bit Set
    50% Off Our Regular Price of $29.99
    E-Direct Price $14.99
    http://www.admail.net/images/image_v...=5e24f0&n=3006
    This high quality carbide tipped Rabbet / Straight Router Bit Set will handle most common edge rabbet and closed cuts in hard and soft woods.
    • 22025
    Can they call that a rabbeting set if it doesn't have bearing guides?
    Looks just like a straight bit set to me. I suppose you could rabbet with it if you had an edge guide and it was a straight board.
    I think of a rabbeting bit set as a ~1-3/8" diameter short profile bit with a bearing guide and an assortment of bearings where the difference in the radius of the bearing and the bit gives you the rabbet width. You can rabbet any curved or straight edge with the bearing allowing you to follow the wood edge.
    Picture courtesy of MLCSWoodworking:
    ken
    6 Piece 1/4" Shank
    • Stormbringer
      • 1387
      • Floral Park, NY
      • Bosch 4000
      Hickory call s the same exact set a "straight bit set"
      The sole reviewer slammed them. Apparently the "high quality" they mention was non existent.
      http://www.amazon.com/Hickory-Woodwo...9?ie=UTF8&s=hi
