Bosch 1617EVSPK w/Bonus Acc. & Freud 99-036 Bit Set: $174.02 shipped
  • Troz
    Handtools only
    • 2
    Been waiting for a special on this, and the Freud Bit Set promotion pushed the order total over $300, allowing for an extra $50 off using the SAVEMORE coupon.
    http://www.amazon.com/Bosch-1617EVSP...5?ie=UTF8&s=hi
  • wouldchuck
    • Sep 2005
    • 70
    • Richmond, VA, USA.
    Thanks for the tip on the Freud bit set. I just used it with the DeWalt 3-base router kit (see new post). I was already on the fence, and that pushed me right over!
    • jackellis
      • 2638
      • Tahoe City, CA, USA.
      It just amazes me how you guys work the system. Are there any other router bit promotions like this one? A set of T&G bits is pretty low on my list of needs.
      • BigguyZ
        • Jul 2006
        • 1818
        • Minneapolis, MN
        What's the Freud Bit Set promotion?
        Edit: I tried to order the whole shebang on Amazon and it worked! One question, Does the Freud promotion apply to any other bit set? I don't really need a Tongue & Groove set as badly as I could use another set... Also, is there an expiration date on this?
        Thanks!
        • jackellis
          • 2638
          Apparently the trick is to find a Freud accessory that brings the total cost to $300 where there's also an Instant Rebate equal to the whole amount. Why they'd give away the T&G bit set is beyond me but my out-of-pocket cost after using a bunch of reward certificates is $49.02. So now I've joined the ranks of routerholics anonymous with a total of four.
          • Jeffrey Schronce
            • 3822
            • York, PA, USA.
            • 22124
            Thanks!
            So far the T&G is the only bits that I see that can be had for free buy purchasing certain qualifying routers.
            • JeremyM
              • 116
              Soooo....
              Is this the same as the old EVSPKE kit?
              Is this a definite good buy for the Bosch, or could it be a bit better?
              Just about to pull the trigger here...
              • Jeffrey Schronce
                • 3822
                • York, PA, USA.
                • 22124
                Originally posted by JeremyM
                Soooo....
                This appears to be almost identical to "E".
                "E" has more router templates (3 v 1) and different dust collection attachments (though the current kit being discussed seems to have a better dust collection attachment as the "E" kits are pretty worthless).
                Pull the trigger if you need the T&G or can sell the T&G to get your net cost of purchase down. Otherwise, another deal, possibly lower cost for the Bosch kit only will likely come along.
                • buddyroo
                  • Aug 2006
                  • 90
                  Not sure what you mean by the necessity of adding a Freud accessory. Here's the math: The router kit is $231.02. The bit set is $69.99. Therefore the total is $301.01. By placing an order for Tools and Hardware of over $300 you get an instant savings of $50.00. BUT, you still get an instant 10% rebate of $7.00 on the bit set. $231.02 less $50 less $7 equals $174.02.
                  Effectively, you are getting the bit set for -$7.00. And even though you are getting the bit set for less than free, they are using the $69.99 price of the bit set to bring your total over $300 and allow you the $50 instant savings.
                    Jeffrey, the picture shows only one bushing, but the write-up says there are three included. Also, the one dust nozzle pictured is the same one I got with my "E" kit.
                    Assuming the dust nozzle that goes on the edge guide is the same (which it probably is???), this combo appears to be exactly the same as the "E" kit, to me.
                    • jackellis
                      • 2638
                      I was referring to the fact that in order for this deal to work, you had to buy something that brought total above $300 and yet the cost of the something got automatically rebated. I could see that the T&G bit set would work but never could find an explanation for the rebate. Since adding the T&G set reduced by out-of-pocket cost by $32 and I figured I could always use it as a slot cutter, why not?
                      A set of bits with 1/2" shanks would have suited me better, though. Most of my small collection is for a 1/4" collet.
                      • BigguyZ
                        • Jul 2006
                        • 1818
                        • Minneapolis, MN
                        What type of applications would a T&G set have? I think that I'll definitely pounce on this when my paycheck comes around.... I might just end up selling the T&G on eBay, try to get a few bucks back...
                        • jackellis
                          • 2638
                          I can think of two. First, panel glue-ups where you're concerned about the strength of a butt joint. Second, for using solid wood to trim out the edges of plywood. You cut a groove in the edge of the plywood and a tongue in the back of the trim piece. Provides more strength than a plain butt joint without having to use nails.
                          I'm also thinking about unloading the T&G set when it arrives.
                          • Jeffrey Schronce
                            • 3822
                            • York, PA, USA.
                            • 22124
                            I think that is what is leading to the confusion. It is not Freud accessories, rather it is this one specific bit set. The explaination is about half way down the page of the Freud Bit Set page.
                            Basically, it says you get those bits free if you purchase certain qualifying routers including the mentioned Bosch, Porter-Cable 7518 3-1/4 HP, DeWalt 3 Sub-Base, etc.
                              Does anybody know when this promotion appeared? I just got my 1617 on Saturday and would like to have a free bit set if I could talk them into it.
                              BTW - it definitely appears that the EVSPKE is caput and the the EVSPK has been upgraded to displace it. I ordered the EVSPKE but the packing slip said EVSPK. It seemed to have most everything it was supposed to have, barring two of the three guide bushings. A call to Bosch got them in the mail to me.
