Don't know what the regular price is, but Home Depot is selling the Herc-U-Lifts for $29 now. They are rated up to 300 lbs.
Ridgid Herc-U-Lift $29
The HD close to me had them for $49.00 before dropping them to $29.00.quote:Originally posted by AcornMan
Don't know what the regular price is, but Home Depot is selling the Herc-U-Lifts for $29 now. They are rated up to 300 lbs. -
I would consider something else.quote:Originally posted by jxyoung
Craftsman micro torque wrench $26 off. Now $48. 9/16 to 9/18
These do not have lifetime warranty, Husky@HD,and HF ones do. I have both and the Husky is better in 1/2" drive size due to 250Dave - Weekend Garage Junkie
"I'm no physicist but I know what matters" - PopeyeComment
These do not have lifetime warranty, Husky@HD,and HF ones do. I have both and the Husky is better in 1/2" drive size due to 250War Eagle!Comment
and it will work with ... what?
These do not have lifetime warranty, Husky@HD,and HF ones do. I have both and the Husky is better in 1/2" drive size due to 250LarryComment
These do not have lifetime warranty, Husky@HD,and HF ones do. I have both and the Husky is better in 1/2" drive size due to 250Jack
Throughout my racing career I was constantly reminded of this: "Keep the pointy end forward and the shiny side up!"
These do not have lifetime warranty, Husky@HD,and HF ones do. I have both and the Husky is better in 1/2" drive size due to 250Last edited by ironhat; 02-14-2006, 03:33 PM.Blessings,
Chiz
Larry,Originally posted by LarryGI would consider something else.
I have attached it to a Delta Contractors saw 36-675 and was very easy to install.
The Herc-u-Lift is Rigid model AC9950 and you can get the owners manual here.
http://www.ridgidparts.com/accessories/AC99500.phtmlWar Eagle!Comment
Nice deal....thanks for the tip.Happiness is sort of like wetting your pants....everyone can see it, but only you can feel the warmth.
Added the Herc-U-Lift to my BT3100 yesterday. If you can get this deal you absolutely MUST do it (if you need to move your saw ever, anyway). I was using the accessory kit casters, and as everyone knows, they suck. For less than $30 and about 2 hours of my time (working slowly) I now have a VERY movable saw, yet VERY stable when parked.
This kit is much nicer IMHO than the other mobile bases, as it has 4 swivel casters, instead of the typical 2 fixed wheels with one or two casters (I have a setup like that on my HF BS and it's ok but not as nice -- but since it's a closed-base BS I can't use the RIGID base on it).
As others have said elsewhere, just use the 28 x 28" configuration and it drops right in. You do need to drill 9 holes in your BT3 stand -- 2 on each leg for the leg supports, and one for the spring which keeps the wheels elevated when parked -- but that was not difficult, and for the functionality added to your saw, there's absolutely no question that I'd recommend this.
One other note -- someone else said that you should use 2 links of the chain with the extension spring -- I found it worked better for me to just use the spring without the chain, using 2 s-hooks at the top for just a little bit less extension. Works great and the BT3 is rock-solid when parked.
Since I have to share the 'shop' with 2 cars, this is going to be my favorite BT3 mod yet...
-TimComment
Tim, good to see you hanging around again.
It appears that the price on the Herc-U-Lift Plus has settled at $29. A guy can barely make a good mobile base for that. Too bad the BT is the only tool for which I can use it. . . .and I'm planning a more "traditional" mobile base in the future.BrianComment
I just purchased the Herc-U-Lift from the BORG. Could someone please post some pictures of a finished Herc-U-lift install on the BT3100. The picture thread: http://www.bt3central.com/forum/topi...TOPIC_ID=27486 does not seem to load…I get a, the page cannot be found error. Any posted install pictures would be greatly appreciated.Comment
online it still shows $49 for me.
i have to go there tonight anyway so ill look for it.
i have 4 swivel/total-lock casters on it but think this might be easier than adjusting all 4 wheels all the time. 30 is worth it for sure
namaste, matthew http://www.tribalwind.comComment
Footer Ad
