The edit Avatar settings are under the settings option vs profil. On the left side of the screen, you should then see a link for edit avatar.
I believe for avatars that you are limited to the state flags and Canadian flag unless you are a SawdustZone patron, but that setup predates my memory. I'll look at it when I get home tomorrow.
I did check and that is one of the patron perks. In order to use your own image as an avatar you need to be a patron. The avatar size is limited to 150 x 150.
