where do I find this nut?
  • durango dude
    • Mar 2011
    • 937
    I bought a drill press at a yard sale for dirt cheap. Now I'm figuring out what I get for my money.
    It's made in taiwan ---- suspect it's a harbor-freight type drill press.
    There's a nut missing ---- one that holds the forward pulley onto the quill shaft.
    The threads of the shaft show 3/4-16 LH.
    There's a challenge, though ----- the nut sits inside the pulley ----- and the pulley is only 1" in diameter.
    So - what I'm looking for is a super thin 3/4-16 nut.
    No stinking idea where to find one ---- none of my hardware stores have that kind of part.
  • cork58
    • 365
    • Wasilla, AK, USA.
    Machine shop?
    Cork,
      McMaster-carr or MSC Industrial would be my first two stops. Many pulleys have nuts like that as part of the pulley.
        Could you buy the nut and grind it thinner?
          • 3790
          I'll look at my taps and see if I have a 3/4-16 LH. Nuts are not hard to make if you have the tooling. It will be Tuesday next week before I can check. The task will 1st you fabricate a nut body that fits in the pulley, then drill and tap it using the correct tap, nothing to it!
          capncarl
          • dangre
            Norum Fewbie
            • Oct 2009
            • 78
            • Gardnerville, NV
            Try a jam nut. Check your local Fastenal store, if you have one.
            Dan
            In a recent survey, 4 out of 5 hammers preferred thumbs.
              • 3790
              The problem is Durango dude is looking for a left hand thread nut. Not common, but not that unusual for machine shops. Don't waste your time looking at the box stores.
              capncarl
              • durango dude
                • Mar 2011
                • 937
                well - I learned more than I wanted about fasteners!
                I need 3/4"-16 LH Thin OD.
                3/4 is thread thickness
                -16 is number of threads per inch
                LH indicates left-hand
                Thin OD means thin outer diameter.
                I might have found what I need:
                http://www.summitracing.com/parts/aa...8289/overview/
                  • 8803
                  Next on the agenda - finding a left handed socket! But, if you can't find one, a counter clockwise socket will do in a pinch!
                  • RAFlorida
                    • 1179
                    ++++ good one, great laugh, lol....
                    • thiggy
                      • 229
                      • Alabama.
                      • Craftsman Contractor
                      I find it surprising that an import tool would have imperial threads rather than metric.
                      SOW YOUR WILD OATS ON SATURDAY NIGHT - - - THEN ON SUNDAY PRAY FOR CROP FAILURE!
                        • 2812
                        Fastenel or other local hardware supplier would probably be the second place I'd look; but first place would be to try to identify who was the manufacturer and then see if I could order the nut from them. I think that most drill presses made in the last decade or two were probably sourced from Taiwan, so the country of origin shouldn't be a problem.
                        I have a Ridgid DP15501 which I bought on clearance in 2003 (old grey paint scheme, 1999). The thread is not the same as yours but the nut on that model's front pulley is an M24 x 1.5 LH. (Ridgid Manual Form No. SP6158-2; Figure 1, Key # 16, Ridgid part number 827142). It makes me think that if your's was made in China or Taiwan, it would also have a metric thread, so perhaps yours is American made.
                        • Stytooner
                          Roll Tide RIP Lee
                          • 4301
                          • Robertsdale, AL, USA.
                          I think you would be looking for a spanner nut. Has a series of slots around the top and the edge.
                          Those are quite common in LH thread, however not sure about the SAE thread. I have had several machine that use this method to hold the pulley to the spindle.
                          Here is one variety.
                          http://www.amazon.com/Whirlpool-2136...s=spanner+nuts
                          And another.
                          http://www.littlemachineshop.com/pro...2127&category=
                            • 3790
                            Durango dude, did you decide were going to purchase a nut or build one?
                            capncarl
                              • 3790
                              Durango dude, I checked my taps/dies and the largest LH thread size tap I have is 1/2". Any machine shop worth their salt will have one though.
