Hard drive disappeared
    I installed a new SATA drive into my HP Win7 desktop PC a couple of months ago. I had to buy a separate power splitter because I was out. Anyway, I just noticed that the drive doesn't appear anymore. On reboot, Windows asks me how to open file "Paul". I don't remember naming the drive Paul, but I could have.
    Before I check the physical connections to the drive, anything in BIOS or Windows I should check?
    Thanks
    Paul
  • Condoman44
    • Nov 2013
    • 182
    • CT near Norwich
    SATA Connections
    I had a SATA that disappear at times. I would remove and reconnect the drive data cable and it would be good for another few months. After trying that see if it can be seen in disk management (diskmgmt.msc).
      Thanks. That worked although I still get that one message on startup. I'll have to look into that later. BTW, the hard drive is not named Paul.
        • 22098
        SATA drives send everything over very fast serial lines, so all the data is on one or two signals. If the cable is intermittent or broken on that one line its over and the computer sees nothing.
        By contrast the old PATA used parallel data lines which were many. If one broke the computer could figure out that one of the lines was stuck and give a data error message indicating a bad drive.
        So its harder to detect a broken SATA cable... Sometimes the computer can only say, you asked for this drive and its not there.
          The bios will tell you if the motherboard see's it. If not then you have two cables to check, power and the serial cable. You could test the serial cable by swaping it for one of the others, same with the power (just make sure nothing is loose first before swapping). Otherwise the drive could have died (does happen, just less likely).
          Also could paul not be the drive, but a file, or home directory on the drive?
