Recently I came into possession of my dads old medium format negatives and slides. These are from 50-60 years ago. I looked into having them converted to digital but there are so many that it would cost between five and six hundred dollars. A decent dedicated scanner would cost at least as much. After much searching on the internet I came across a site that gave me some ideas on how to use my DSLR to take convert these to digital. I don't own a macro lens so I calculated the minimum focus of my 55mm lens and went from there.
The basis of my assembly is a cardboard tube cut to the required length. This sits on a 2x4 with a v-groove cut out for stability. The end of the 2x4 has a removable mount for my camera. The opposite end has a frame built to hold the negatives/slides in position. The slide/negative is backlit by a simple light separated by a diffuser made from tissue paper in a picture frame.
It's not pretty but it works well for the purpose. I simply mount the media in the one end and snap away. I have tried various settings on my camera but I have found the auto with it set on the automatic depth of field turned on. Once uploaded to my computer, I use GIMP software to convert and enhance. I'm still learning the software but the results are promising.
My dad( on the left) with his brother-before my parents met.
The Stelvio Pass( From a trip my dad made through Europe back in 50's perhaps?)
I'm in the process now of turning everything to digital. I hope to set up a few blogs once done to share on line.
Thanks for looking.
Thanks for looking.
LCHIEN
