Oh no!
    • 3773
    I have a good variety of sizes of toggle clamps that I use on jigs and use for hold downs on the CSMS. Usually there is adequate adjustment on the threaded hold down bolt on one of sizes of clamp to do the job. If you have numerous cuts to make with the same size wood they are ideal and quick, not as good if you have to adjust each cut because of wood thickness, but still quicker than trying to invent a one sice fits all clamp for each application.
    My favorite is a 9" Deluxe Drill Press Clamp. I could not find it at HF the last visit. It has a swivel base with 2 holes that accept "T" bolts in a t slot, drill press or band saw. Google Highland Woodworking, you will have to have a set.
    capncarl
