Why does Home Depot check my age when purchasing polyurethane?
  • BadeMillsap
    • 868
    • Bulverde, Texas, USA.
    • Grizzly G1023SL
    I admit to being an old and out of touch dinosaur when it comes to many things people are "up to" nowadays ... but ... I have to ask ... why ... when purchasing a quart of Minwax polyurethane at the self check out register did I have to "wait for the attendant to verify my age ..." ??? What in blazes can you do with brush on polyurethane that requires an age check? I do understand the requirement when buying spray paint in pressurized cans ... it's a sad circumstance but I understand the need ... but brush on poly???
    Bade Millsap
    Bulverde, Texas
    => Bade's Personal Web Log
    => Bade's Lutherie Web Log
    You could just as easily get high by huffing polyurethane in a brush on can as you could from an aerosol can. Look up "huffing".
      How do they verify your age? Just look at you or ask?
        Why couldn't a "huffer" be an old guy?
        • schloff
          • 229
          • Southern Middle TN
          • Powermatic 64 (BT3000 RIP)
          Quick answer is because this country went and screwed itself up. (trying to keep this non-political, so I'll stop right there on that)
          Kids don't have any idea what they are doing to their bodies and minds, nor care. It's a disturbing craze, but not as scary as meth. That crap is just bad news.
          • BadeMillsap
            • 868
            • Grizzly G1023SL
            Sigh ... I was aware of "huffing" spray paint .... poly? geeeeeze!
            Bade Millsap
            Bulverde, Texas
              It's got mineral spirits as an ingredient, which has it's own warnings.
              • akronee
                • Dec 2011
                • 36
                • Denver, CO
                • Craftsman 315.228110
                Lowes has asked for ID from me for danish oil. I can't imagine what someone would have to do to get high off it.
                  • 22029
                  So I have to watch for some visiting teenagers sniffing my freshly oiled teak coffee table?
                  Don't lean over the table and breathe in when watching TV?
                    By "freshly oiled" if you mean wet, yes, don't let them lean over the table. They might just fall into it, and that could ruin the finish.
                    If it has dried, it's OK. It would then be food safe, and they could lick the surface safely providing there were no splinters.
                    • woodturner
                      • Jun 2008
                      • 2049
                      • Western Pennsylvania
                      That sounds like someone applying a policy too broadly. I guess you could sniff the fumes, but unless you are eating it or using it in applications where it could be ingested (such as toys or products used with food), it's relatively safe. Even then, although it's not "food safe", Danish oil is only slightly toxic when fully cured - you would pretty much have to eat the cured oil itself in large quantities to suffer any serious effects.
                      The biggest danger with polymerizing oils is spontaneous combustion - so be careful with those rags and brushes.
