well duh......
  • durango dude
    • Mar 2011
    • 937
    well duh......
    @ me.......
    Been practicing mortises ----- and could not for the life of me, figure out why I was coming up - typically 1/8" off the target mortise width of 1/2".
    Well - after scratching my head --- measuring - re-measuring - and groaning for awhile - I found the missing width ----- it's the kerf of the saw blade!
    I've been using Kreg setup bars -
    The plans call for cutting off 1/4" - so I grab my 1/4" setup bar - and gap the blade - then cut. I'd forgotten to count the blade kerf ---- which would add to the measurements.
    Well, now that I've figured it all out - I'm hitting 1/2" mortises on the head.
    Good news is --- I've been using scrap wood to practice with!
    palm slaps forehead....
      That's not uncommon. Getting used to figuring "save", "waste", and kerf gets familiar.
      • Brian G
        • Jun 2003
        • 993
        • Bloomington, Minnesota.
        • G0899
        Glad you solved your mystery.
        I started the habit of marking an "x" on the blade side of the cut line when I mark out a cut on the stock. That way, if I use a stop block or some kind of setup bar, I can make a "pretend" cut and see where the blade is relative to the cut line.
        I have fewer 1/8" and 3/32" mysteries since I started doing that.
        Brian
        • gsmittle
          • 2793
          • St. Louis, MO, USA.
          That's a good idea. I teach my scene design kiddies to put an arrow on the waste side pointing to the line. Didn't stop me from putting a 3/4" dado on the wrong side of the line though.
          g.
          Smit
          "Be excellent to each other."
          Bill & Ted
          • phrog
            • Jul 2005
            • 1796
            • Chattanooga, TN, USA.
            Durango Dude, you're the only one on this site who has ever done that.
            Richard
              That's not true...I've done it.
              • phrog
                • Jul 2005
                • 1796
                Me too. But don't tell Dude.
                Richard
                • BobSch
                  • 4385
                  I'll bet everyone here would admit to that.
                  Bob
                  • Bruce Cohen
                    • 2698
                    • Nanuet, NY, USA.
                    Nope, Not me, I just put a finger in the way, bloddy, but accurate
                    Bruce
                    Samuel Colt did"
                    • radhak
                      • 3061
                      • Miramar, FL
                      • Right Tilt 3HP Unisaw
                      No, that's good planning - that's what 'practice' is for! Good for you!
                      - Aristotle
