metric tool idiocy
    • 22023
    metric tool idiocy
    noted today in tooliday
    So this is a metric adjustable wrench?
    Why is it listed as 6 inches then, rather than as a 15 cm wrench?
    And how is a continuously adjustable wrench suited for metric nuts but not SAE or imperial inch-based fractional nuts? Won't it fit either?
    Shouldn't they have called it a universal SAE/metric adjustable wrench (sounds much better to me) --they'd sell twice as many.
    such metric silliness.
    If we're not already importing them maybe we should export them!
  • TB Roye
    • 2969
    • Sacramento, CA, USA.
    The discription was probably written by some one at Irwin who has no clue about wrench's and no clue about SAE or Metric size nuts. and bolts.
      Probably bad type. Typically, these are marked metric on one side and SAE on the other. Looking at Amazon, there are others that appear to use metric only markings by the opening (allows one to see the size of the nut for getting a replacement).
        Now, that makes sense. Sorta like a redneck caliper.
        • woodturner
          • Jun 2008
          • 2049
          • Western Pennsylvania
          The difference is that this wrench has a scale that is calibrated in mm, so you can measure the size of the opening and therefore the fastener head. It will work on either, of course, but the measurements are in mm.
          I assumed they used the 6" designation because people in the US have an intuitive sense of inch measurements but not really metric. Calling it a 150 mm wrench (or 15 cm or 1.5 dm) would confuse most people and they would have to convert it to English in their head (and their inability to do that is a discussion for another thread).
          • Daryl
            • 831
            Blowing up the picture, I see the scale is in sixteenths.
            • Tom Slick
              • 2913
              • Paso Robles, Calif, USA.
              • sears BT3 clone
              Back when I was a mechanic in the USAF I'd tell the newbies that the "Metric" and "Inch" markings indicated which side had to be facing out when you used it. Everything we worked on was "Inch" so "You'll strip the fitting if you use the wrench with the "Metric" side facing you. It worked on a few guys but it always got a good laugh.
              • Brian G
                • Jun 2003
                • 993
                • Bloomington, Minnesota.
                • G0899
                Irwin's website doesn't confuse the two.
                Adjustable Wrench
                I'm passing responsibility to Tooliday for the description.
                Brian
                • sweensdv
                  • 2872
                  • WI
                  • Baileigh TS-1040P-50
                  Did you ever send any of them over to Supply to pick-up a few hundred feet of Flight Line?
                  • woodturner
                    • Jun 2008
                    • 2049
                    Yeah, looks like they used the wrong photo as well.
                    • Tom Slick
                      • 2913
                      • sears BT3 clone
                      Flight Line and a bucket of K9-P. Also they'd need to get some Prop-Wash
                      • durango dude
                        • Mar 2011
                        • 937
                        Sears has them, too!
                        http://www.sears.com/search=Quick%20...rod=1605981018
                          I thought I saw a special sale on metric bubble levels.
                          • durango dude
                            • Mar 2011
                            • 937
                            Found out my neighbor bought the combo set ----- one of the wrenches is metric, the other is standard.
                            • eezlock
                              • 997
                              • Charlotte,N.C.
                              metric tool idiocy
                              I guess that the next or "updated version " will come out as either a right or
                              left handed version ? what do you think?
