I learned a trick, today.
I was staring at my Craftsman router bit set, and realized that I had two (2) different bearing sizes between my straight pattern bit - and my bead bit.
I swapped the bead bit bearing to something a little bit bigger - and voila - the bead bit became a roundover bit!
Guessing most of you vets already know about this trick - but I'm thrilled to figure it out.
http://www.freudtools.com/p-143-rounding-over-bits.aspx
