Lamello magic dowels
Bade Millsap
Bulverde, Texas
=> Bade's Personal Web Log
=> Bade's Lutherie Web LogComment
LOL, nice
I wonder how these things will perform in real life scenario's of mass produced parts with loose tolerances and perhaps parts that just don't line up properly. Will that magnet be able to induce enough of a field to transfer adequate torque? I saw the graph they included, but it makes me wonder a bit.I think in straight lines, but dream in curves
basically its a magnetic slip clutch.
You won't know when it tightens up.
And, the loosening torque is the same as the tightening torque. What if it freezes a little or there's some corrosion or whatever, you can't break the joint loose.
And of course, that presumes you remember where all the fasteners are a couple of years after you made the thing... there's no hint of where they are so forget the location of one and you'll destroy the thing to take it apart, about the same as dowels but a lot more costly.
It is a very cool idea. You could have a screw right through the front of the cabinet that would lock this device in place and eliminate just about all of Loring's issues with it.
Sure, you would see screws, but you would be able to make sure it wouldn't loosen up on it's own or get lost in time.
LeeComment
As Jussi noted this fastening has been around for years and is proven.
I do not build that much furniture any longer, but if I did I might give it a try.
As far as locating the fastening after assembly, the locations would be on the plans, filed in the cabinet in my shop. Not that big a deal I think. Of course all of you guys that are very visual and work from plans in your head would need to adapt.
The locations could also be marked on the inside of most joints where they wouldn't be seen. Newels and posts, table and chair legs are easier as they are in the middle of the piece in probably 99% of most builds and mostly likely wouldn't need to be marked. Desks top joints could be marked on the underside. I just do not see a down side other than its another tool and fastener for the shop that doesn't seem to be any better solution to joinery than plate jointing, wood dowels and the like. And it'd easier to disassemble than joints that have been glued.
Of course you craftsmen will never give up your hand made joinery. I envy the talent and patience of those of you who can lay out a dovetail, cut and assemble a joint that is not only functional but also a visual statement of your craft.A man without a shillelagh, is a man without an expidient.Comment
That's what helps make it satisfying. All it takes is practice, and the right tools.
.Comment
LCHIEN
