zero clearance isn't flat!
  • durango dude
    • Mar 2011
    • 937
    I've had my bt3000 for 2 years - and just noticed tonight --- that my zero clearance insert is actually a tiny bit higher than the saw's surface.
    Guessing this has been ranted about before - but it does help explain why I'm not getting perfect 90 degree cuts!
  • jking
    • 972
    • Des Moines, IA.
    I've noticed mine is actually lower than the top.
      • 22109
      Most of them I heard of were too low.
      Shimmed mine up with self-stick metallic return address labels cut into strips.
      • RangerRick
        • Jun 2011
        • 25
        • Mass.
        • bt3000
        Shimmed mine up with some brass shim stock
