I suppose practice makes the difference but IMHO it's easier to fly from inside the airplane than from outside. This guy has obviously spend a lot of time and a lot of money honing his hobby...er craft...er skill. Very impressive.
Unbelievable! I guess even with a ton of practice that would not happen for me. I had a remote off road car and a yard with 3 trees. It seemed to find the tress every time! I finally gave up.
There is a fellow who probably wouldn't have to work again! He could play around at every Fair, and aviation get together around the US, Sell His talents and try to teach flying classes where ever He goes. I wish I was as good at building stuff in My shop as He is at flying that plane!
I have Hope, and I am Thankfull! Consider WhoWhoGreated it ALL
That must be one powerful powerplant spinning that prop...
High power to weight ratio, but I'd bet on very low weight rather than a really powerful motor. The power to weight ration in my airplane when fully loaded is 1/12 HP per pound, (or 12 pounds per HP). When I flew out of Tahoe last Thursday, it was more like 10 pounds per HP with just me and 30 gallons of fuel and I could climb like a rocket. Tower Hobbies has airplanes in this size category and it appears they weigh around 20 pounds. I have no idea how much power the recommended 35cc engine makes.
Impressive. How does the plane fly horizontally with one wing pointed at the ground and the other at the sky? How does it generate lift with the wings vertical?
The plane was pitched upward (sideward?) about 25º. So the prop was providing the lift (upward force) and forward (sideways to the ground) motion. The speed was relatively high, so air was moving around all the control surfaces allowing the (extremely skilled) pilot to maintain control.
Not that being able to explain it makes it any less impressive.
No wonder it was off the ground in ~3 seconds.... 50+ lbs of thrust is phenomenal. When I was younger I had an interest in model rockets and the engines were all small, no more than 2-3 lbs of thrust.
