Anyone ever make a muffler for their generator? I've read that much of the noise is from the mechanical parts so a muffler might not do any good. Is covering it with a wooden box that's lined with foam insulation a crazy and dangerous idea?
Generator muffler
I would think wood would be a no no.
I too get concerned with the noise of my lawn tractor (20HP B&S). I want to run it at 6 or even 7 AM or even at 8 - 9 PM, but it sounds like a lawnmower and I know that I would get some complaints.
There are a few after market mufflers and I found one here but it would not fit mine. I am amazed that so far there has not been an EPA regulation that requires lower noise mufflers. NOT that I want it but I know people that complain about loud motors.
In your case, if you are wanting to use it through the night and need a quieter muffler, all I can say is search the internet and see what you can come up with. You might even find a site that gives recommendations on a home made one - if you know of a good welder or machinist.Last edited by leehljp; 08-23-2011, 04:51 PM.Hank Lee
We lost power for 15 days after Wilma. There were generators (including mine) that were running 24 hours a day all over the neighborhood. It was more like an orchestrated hum. Fortunately there were small ones and large ones which took some of the monotony out of the sound.
.Comment
Just discovered your (older) post. As a youth I wanted to make an old mower engine louder (I was younger, now suffer hearing loss.), a college friend did some math for me, determining resonance, engine RPMs, exhaust pipe diameters, etc--ended up with a section if straight pipe. I do not remember the specifics, but likely something similar could be done to minimize the volume if you can find someone capable of the math.Comment
Jussi, alot of the noise that you can attenuate is what's escaping the combustion chamber as the valves open. You can try using a tube in tube design with fiberglass packed around the outside of the inner tube. The inner tube is riddled with holes while the outer serves as a casing. You should be able to make one pretty cheap. Just measure your exhaust pipe inner and outer diameter. You may need to construct some type of support for the extended tube perhaps even reroute a portion of its section. Just remember the longer you make it the more restrictive it may become and you don't want back pressure. HTH GLI think in straight lines, but dream in curves
A tight box around a generator? BAD idea!
A "generator shed" where you insulate the walls for noise reduction instead of thermal protection? Those are all over the place here.
You would need to insure proper air movement for thermal and combustion reasons, not to mention the safety of any humans or animals that ended up in there...
Just google "generator shed" and have fun seeing what is out there...
FWIW, I am n a subdivision with lousy windows, and tiny yards. After Ike a LOT of my neighbors had generators running 24x7 for at least 2 weeks, and the sound in the house was no worse than say a running air conditioner... And that was the ones without the generator sheds. The sheds cut the noise back about 50%. I know a lot of older / cheap generators made a LOT more noise than the newer models... I think newer muffler designs would work better...Please like and subscribe to my YouTube channel. Please check out and subscribe to my Workshop Blog.Comment
Thanks for all the tips. Helping a friend renovate a house he just bought. Electrical is shot so he's going to have the whole house rewired. Hence the need for a generator. Since it's going to be a temporary use (depending on how fast electrician is) I don't think building a shed will be practical. We're gonna run it as is and see if any of the neighbors complain. If they do, we'll try some of your suggestions.I reject your reality and substitute my own.Comment
Years ago I had a generator with a 3/4 in. pipe nipple coming from the ehgine. The factory muffler screwed onto the treaded end. I took it off and welded an old car muffler in its place with some adaptations of course.
It was veery quiet until the vibration allowed it to break off. I did not have it supported very good. After that I just reinstalled the small muffler.
ConwaygolferComment
