A good deal on a soldering/hot air rework station
  • Alex Franke
    • Feb 2007
    • 2641
    • Chapel Hill, NC
    I didn't put this in Bargain Alerts because it's not really related to woodworking, but I know a lot of us here like to make stuff even if it's not out of wood...
    I was replacing a soldering station and ran across this soldering and hot air rework station for around $80 shipping included, and that's a pretty darn good deal for an occasional user. It looks suspiciously similar to Chinese units sold under a number of different brands. I'll take a chance on it and see how it holds up. http://www.amazon.com/gp/product/B004ZB9D4O
    • 22002
    yeah those are knock offs of the Hakko stations.
    Got one last year for the lab at work, a Quakko, it takes the Hakko accessories. Seems to work OK.
    • dkerfoot
      • 1094
      • Holland, Michigan
      Let us know how it works. That is pretty tempting!
      Doug Kerfoot
      KeyLlama.com
      • Alex Franke
        • Feb 2007
        • 2641
        • Chapel Hill, NC
        I just did a quick test of the soldering iron and the hot air gun and so far they work like a charm. The tiny SMT chips just pop right off -- couldn't be easier. When you flip the switch off the unit even stays on for a bit blowing air until it reaches a safe temperature.
        It would be nice to have temperatures in F as well as C, but for the money so far I'm not complaining.
        @LCHIEN - I love the name "Quakko!" LOL
        • gerti
          • 2233
          • Minnetonka, MN, USA.
          • BT3100 "Frankensaw"
          Does the soldering iron lay good in the hand, and is the cable leading up to it more a normal one or one of those really flexible teflon cables?
          Thanks
          Gerd
          • Alex Franke
            • Feb 2007
            • 2641
            • Chapel Hill, NC
            It seems fine to me -- probably a bit more comfortable than I'm used to, but I've only had cheap irons before. Its not as solid or comfortable as others I've used from time to time (but not owned myself). The iron cable is round and flexible, and I can loop it pretty easily down to about the size of a quarter. It has a 5-pin plug. The hot air side is a thicker tube, and loops down to about the size of a quart paint can before it starts to kink.
            I can try to get you some pictures tomorrow if you want. Let me know...
              I am going to ask a stupid question as the only one I would have known to use one of these, is dead. Do these only hold irons, and if so the largest?
              I tend to use guns a lot more then irons, but know even the old manual soldering irons are useful (friend just used a LARGE one in his hot rod building).
              Thanks
                • 22002
                Thanks
                these tend to be for microelectronics work, where the leads are .025" apart. not for plumbing and welding and such so the irons are small, 15-watt or so and have leetle tiny tips.
                • Alex Franke
                  • Feb 2007
                  • 2641
                  • Chapel Hill, NC
                  This one came with a number of tips -- point, fine point, chisel, spade, etc -- and they're meant more for detailed work like LCHIEN says. I can measure the tips for you tomorrow if you want; just let me know.
                  This unit is listed as 700 watts with temperature ranges from 100-500 degrees C (212 to ~930 F) on both the iron and the hot air.
                  The hot air is mainly useful for removing surface-mounted chips and shrinking heat-shrink tubing, but I admit I'm tempted to cook dinner with it tomorrow.
                    • 22002
                    probably make a good Creme Brulee.
                    • gsmittle
                      • 2793
                      • St. Louis, MO, USA.
                      Wonder if there are Wakko and Dot models… All made by the Anamanialectronics Company.
                      g.
                      Smit
                      "Be excellent to each other."
                      Bill & Ted
                      • jnesmith
                        • 892
                        • Tallahassee, FL, USA.
                        I have no idea what that thing is. Do I need one?
                        John
                        • dkerfoot
                          • 1094
                          • Holland, Michigan
                          Not unless you are into repairing electronics.
                          Doug Kerfoot
                          KeyLlama.com
                          • jnesmith
                            • 892
                            Nope, I'm only into purchasing them. And occasionally even using them.
                            John
