Something for Loring
    355/113 is a little closer than 22/7
    • charliex
      • 632
      • Spring Valley, MN, USA.
      • Sears equivelent BT3100-1
      I know that Pi is an irrational number because the cartoon says so. That may explain why I don't have a lot of real friends. I do have some (i) imaginary friends, why is that? Might it have something to do with n! ?
      Chas
      • Mr__Bill
        • 2096
        • Tacoma, WA
        I can't speak for Loring but most of my imaginary friends are the rational ones.....
          Quite good, close to 6 decimal point accuracy. 402 ppm actually. I might use this but most all my calculators have Pi buttons or I can use Pi() or 2*ACOS(0) in excel when i want accuracy.
          Actually all my electronics calculations usually use 2Pi and I just use 6.28 as close enough when most resistors have 1% tolerance and capacitors have 5% tolerance.
          • Mr__Bill
            • 2096
            • Tacoma, WA
            Seems if you really want to be accurate you should use these guy's calculation. Personally when estimating I just use 3 or pumpkin whichever seems appropriate.
            • BobSch
              • 4385
              Remember life is complex, it has both real and imaginary parts.
              Bob
              • gsmittle
                • 2793
                • St. Louis, MO, USA.
                Mathemeticians (but not EEs) use the symbol i for the square root of -1, which is an "imaginary number". (EEs use j instead of i, to avoid confusion with electrical current i)
                Pi is a "rational number", meaning it can be expressed as a fraction. Pi is exactly 22/7, or approximately 3.14159.....
                Nothing about this explanation (or Loring's one after) is rational.
                Thanks, BW, I'm needin' a friend around all these math whizzes.
                g.
                Smit
                "Be excellent to each other."
                Bill & Ted
