Is anyone here experiencing any planer snipe that is annoying them? Well, I was
until I just tried something...maybe not new to the forum...but thought I would throw it out anyway. I decided to cut a piece of 1/4" white melamine board
the size of my planer bed. I the attached some double sided tape at each end and corner 3 pieces about 1&1/2" long.
I then pressed and clamped this down to the planer bed for a few minutes and then proceeded to try and plane some boards as a test sample and see how well it works. Well, my results were the best this planer has ever done since it was new. One very small, light, mark across the end of the board about 3" from the end.....a very marked improvement over the other methods I have tried to eliminate snipe in the past! I planed two rough construction boards (2x4's)I had lying around, they now look as good as S4S lumber from the BORG. It worked well for me, so I thought someone else here might benefit from the same from their planer as well...hope this works for you!
