What wood scraps can I smoke/BBQ meat with?
    I'm gathering quite a pile of cutoffs that won't do me much good except as
    kindling.
    I've got walnut, maple, and cherry. I haven't heard of smoking/BBQing with
    walnut or maple. I think I have heard of using cherry. Is this safe?
    It's a shame I don't use hickory or mesquite.
    Thanks,
    Paul
    kindling.
    Thanks,
    Paul
    The hardwoods you listed are safe to use. Different woods impart different tastes. Woods with a lot of resins or sap don't smoke well. Try to avoid conifers such as pine, cedar, cyprus, fir, spruce, or redwood. They contain too much sap.
    • phi1l
      • Oct 2009
      • 681
      • Madison, WI
      I don't like the taste of cherry wood much, but maple is nice
        Most fruitwoods (apple, peach, citrus) make good smoke. Hickory and mesquite, too...
        • Bruce Cohen
          • 2698
          • Nanuet, NY, USA.
          I've heard that Pressure Treated great, unfortunately, I don't think there are live folks around to testify to that.
          Bruce
          Samuel Colt did"
          • Hoover
            • 1273
            • USA.
            In the pacific Northwest, alder is used to smoke salmon, clams, mussels. Cedar is used as a plank to cook salmon over an open fire. Of course the cedar is soaked in water before using.
            No good deed goes unpunished
            • jussi
              • 2162
              I heard evergreens were bad. Cedar, pine, fir, etc.
              • jackellis
                • 2638
                • Tahoe City, CA, USA.
                Salmon cooked on a cedar plank is excellent.
                • jussi
                  • 2162
                  I meant wood to burn. I read (although no direct experience) that these types of evergreen, including cedar, gives a nasty taste.
                  • BrazosJake
                    • 1148
                    • Benbrook, TX.
                    • Emerson-built Craftsman
                    I would avoid almost anything decay-resistant as they tend to be oily and stinky (excepting white oak).
                    As someone said, any fruit or nut producing tree.
                    I use a lot of hickory as it's cheap and I like the appearance. I save my plane shavings for fire starting.
                    Down here, we use mesquite for smoking a lot. It's amazing how something that is cursed as a pest and used as cheap firewood can command $10 PBF as lumber.
                    • nadz
                      • 82
                      • Rocket City, AL, USA.
                      smoker woods
                      i use oak, hickory, pecan, and almost any fruit wood...hickory is preferred, pecan is scarce, oak is nice and mild
                      Proudly piddling in my garage shop | BT3K, Rigid 10" CMS, Rigid 12" Planer, HF Jointer
                      • scmhogg
                        • 1839
                        • Simi Valley, CA, USA.
                        Paul,
                        Go easy with the Walnut. It leaves a nasty taste.
                        Check this link.
                        http://www.3men.com/whatwood.htm
                        Steve
                        • Dirty Dave
                          • Mar 2007
                          • 18
                          • Bethel Park, PA
                          • Sears 21829
                          A friend of mine cooks chicken over an open cherry wood fire pit. It is fantastic.
                          Born to Pump
                            Thanks everyone. It looks like it will be a yummy summer. Ashes to ashes.
                            Paul
                              • 9560
                              Any fruit / nut bearing hardwood should be fine. Each gives a flavor all its own. I use a lot of Pecan / Mesquite and tend to use a blend of the chunks for smoking. Remember though, smoking wood is not dry wood. To use woodworking scrap as smoking wood, you should thoroughly soak them prior to use, or they will simply burn up in a flash and be no good for cooking...
