Overkill?
    Overkill?
    I used my DP to drill holes in the lid of an old plastic screw container to make a house for a caterpillar my daughter found. Was using the DP overkill or was setting up the fence and stops to space the holes evenly?
    I would have done the same.
    takes no longer than a hand drill, maybe faster because the DP is already out and set up, the fence is there and all.
    Drill bit won't walk, bit won't break, can control the drill force enuf to cut but not crack the plastic.
    And the end result is nicer and cleaner holes and practically professional looking.
    Overkill would have been using an CNC mill to drill the holes.
    • phi1l
      • Oct 2009
      • 681
      • Madison, WI
      Not unless you wanted a chance to drill a hole in your finger too
        • 2812
        Not at all, that's WHY you have a drill press. Heck, tonight I used my drill press to drill eight holes in the base molding to mount a couple of outlet boxes! (The molding will go around the window seat in the library.)
          Overkill? Nah... However, if you had modeled the fabrication in CAD, and done it on a CNC machine, then you might have some issues to worry about...
            Ha.. ha... ha..ha..ha..!
            • DustyandLefty
              • 74
              • Almost West Virginia
              • BT3000 w/ side and rear tables on wheels, BT3100 portable spare, old Delta contractor's
              yes
              May I offer a polite dissent? Waaaay back about 50 years ago the technique was to have the finder of the caterpillar punch holes in the lid with a nail and light hammer while dad supervised!
              DustyandLeftyandOldy
                I would dissuade my child from putting a caterpillar in a jar. Seems kinda cruel to me. They do make good munchies though.
                • gsmittle
                  • 2793
                  • St. Louis, MO, USA.
                  The child or the caterpillar?
                  g.
                  Smit
                  "Be excellent to each other."
                  Bill & Ted
                  • x00018
                    • 55
                    • Cranberry Twp, PA
                    • Sears BT3000 Clone
                    Of course it is overkill. I shot from a shotgun would have put all the holes needed with just one pull of the trigger.
                      Yea, but what's going to be left of the caterpillar.
                      • Santa Clarita Len
                        • 166
                        • Santa Clarita Calif.
                        • Bt3000 and Dewalt radial arm saw
                        Overkill? You are asking me? Me, who uses the drill press to drill the eyes in a fresh coconut to extract the milk?
                          so what we have learned is that around 50 years ago David punched holes in the top with a penny nail and $2 hammer. Now around 50 years later, David is still punching holes in the top, but now with a $4 carbide bit and a $250 Drill press, but he's still the one doing it.
                          You can separate the men from the boys by the price of their toys.
                          • pierhogunn2
                            • Sep 2009
                            • 134
                            drill press, original lid? why didn't you run down to wood craft, buy a turning blank of the appropriate size, turn a new lid, and then carve some lacework into the top if said newly turned lid . . .
                            nah, that would be overkill
                            • phi1l
                              • Oct 2009
                              • 681
                              • Madison, WI
                              What's gonna be left of the glass jar??
