Making A Pump
    Making A Pump
    As an offshoot of some plumbing questions my 5 yr old asked me, I am designing a hand pump - think the old-school ones with the long lever handle. The mechanics for the lever handle are simple enough, my question was on the pump cylinder itself. Right now I am thinking about 3 or 4" PVC with a T on the bottom. 1 side of the T would be intake, other side would be exhaust. There would be check valves on the intake and exhaust. I would cap the bottom of the T. I would probably arrange the intake to be gravity fed. The only thing I have a question on is making the piston in the pump. Wood will eventually rot. I was thinking along the lines of cutting down a fitting that matches the ID of the pump cylinder and adding a rubber stop to it or something.
    Any ideas?
    One consideration is to not make your stopper too thin. This will prevent it
    from rocking in the pipe and cause water to bypass it.
    You could make 3 discs out of ipe decking which I'm told can be submerged for years without showing wear. 2 discs to match the ID of the pipe and a
    3rd disc sandwiched in between but at a smaller diameter. Around that middle
    disc, you snap on your O-ring.
      Paul, thanks. I was actually thinking about the composite decking, but ipe would work as well. Another idea I had was it occurs to me there are rubber stoppers designed to fit into drains and you tighten a bolt down to expand the rubber up against the walls of the pipe. As I recall, they are backed by a metal washer. I might try that, just not tighten the bolt all the way.
      Now next question is, would PVC withstand the pressure needed to lift, say the water in a 1.5" PVC pipe 6' or so? I am not sure how to figure that out.
      • FL Buckeye
        • 187
        • WC Florida and Crossville, TN
        • BT3100, Grizzly 1023SL
        If you have any scrap flat plastic material, maybe from making a jig or guide, you could use it for the 3 discs as Paul suggested. Or just use two discs and sandwich a piece of rubber, like bicycle inner tube between the discs for the seal.
        Lanny
        The older you get, the better you used to be.
        • Shep
          • Nov 2008
          • 710
          • Columbus, OH
          • Hitachi C10FL
          What about the rubber from a hockey puck? I'm sure you could mill it down to size.
          -Justin
          shepardwoodworking.webs.com
          ...you can thank me later.
            These should help you out.
            http://www.ehow.com/how_2292117_make-hand-pump.html
            http://en.howtopedia.org/wiki/How_to_Make_a_Hand_Pump
              Cabman, that first link does help. Thanks.
              • Tom Slick
                • 2913
                • Paso Robles, Calif, USA.
                • sears BT3 clone
                Maybe you could use HDPE from a cutting board.
                  I am thinking lexan or UHMW for the discs, I have some of both. For the rubber seals I have way more ice dam then I will ever use. I think I will stick two pieces together and cut the circles out of that. I am also wondering if the T idea with check valves would scale any better for a big pump.
                    its easy. You need to raise water 6' then you need 6 feet of head or 6 feet of water pressure (feet of pressure is a measure of pressure, JUST DIFFERENT UNITS THAN psi). regardless of the diameter, just the column height.
                    The conversion for feet of water to PSI is approx 1/2 PSI per foot. So you'll need a minimum iof 3 psi to raise water 6 feet. Just about any PVC pipe of any schedule will withstand 3 PSI.
                      Thanks Loring. Now I need to get some parts and do some experimenting. I like the T idea better. I will let you know how it goes.
