If you remember previous posts, the motor would crank but not turn over. Turned out to be the crankcase full of fuel and there was gas in the oil. My mechanic cleaned out the carb and it was running fine for about a week. Last weekend, same problem. This weekend I changed the oil and added a cutoff to the fuel line. I suspect the carb needs a rebuild but don't have time for that right now. The fuel cutoff is a workaround. After I did the work today I tried starting it and got nothing, no cranking no nothing. It is possible I messed up a safety switch somewhere or did something to the electrical connections. The battery is 2 weeks old so I doubt it is a bad battery.
Mostly this thing has been a thorn in my side since last fall with one problem or another.
