Darn near burned down the house yesterday
  • Knottscott
    • 3815
    • Rochester, NY.
    • 2008 Shop Fox W1677
    Yesterday morning I was messing around with our prewar era Lionel train set that had belonged to my Dad. The wheels weren’t getting good traction, and since I happened to have some steel wool readily at hand, I grabbed a piece to wipe down the track. Unfortunately, I chose to do this while the train was running, not thinking about the short circuit I’d be causing with the steel wool. To my amazement, the steel pad immediately went up in flames in a shower of sparks in my hand, caused by contact with the track. My first reaction was to try to blow it out, which only made it worse, which then caused me to drop the pad recklessly…it landed on some nearby poster board. It was still glowing orange with no flame, but the sparks were showing no signs of going out. Afraid of full blown flames resuming, I managed to pick it up again and dropped it to the vinyl covered floor. Then I managed to grab a rag and pick up one end of the pad and ran it to a sink.
    All’s well now, but WOW!...what a surprise, and what a tragedy this could have quickly become. It happened so fast, and could have easily turned into an all out fire had something else caught fire. I was just having coffee and enjoying some childhood memories one minute, then panicking and wondering if my house was going to burn down the next. Fortunately, my wife and most of the kids were out of the house, and fortunately nothing else became of it, but it did scare me and reminded me what a fine line we walk sometimes. I should have known better, but didn’t give it a thought until after....steel wool is an excellent fire starter, and holds spark for a long time.
    Be safe my friends!
    When I was 13 or 14 I was making my own ignition system for my model rockets. To test it I hooked the leads to one of the igniters. It worked great - the igniter lit off but I didn't notice it was resting up against a pack of engines. All it did was melt a hole in the plastic packaging and the igniter has to be jammed up inside the engine to work - there is a clay retainer on the end - but it was still scary.
    Oh and as for cleaning the track, we were told by a friend of my dad's who had his entire garage filled with a train layout to use a pencil eraser. Steel wool leaves bits that will either short the track or burn up.
    • Stytooner
      Roll Tide RIP Lee
      • 4301
      • Robertsdale, AL, USA.
      A 9 volt battery and steel wool can be added in a survival kit. Makes good camp fires easy to make.
      • os1kne
        • 901
        • Atlanta, GA
        That was my first thought. I haven't started a fire that way in a while, as it's not the most convenient way - but it does work well.
          When I had trains, I routinely used a drafting-style electric eraser with pink rubber loads. Then, just a puff of compressed air...
            My best friend in high school and I almost burned down his house trying to
            make rocket igniters from steel wool. I was doing something and he hung the
            wool stretched out a nail on a basement joist---then he touched a 9V to it.
            Because so much surface area was exposed, that sucker went up FAST. A
            lot of hushed cursing and stomping passed before we put it out and then his
            mom yelled down, "What's going on down there? Do I smell smoke?" Our
            rocket days didn't last too much longer after that.
            • ironhat
              • 2553
              Man, I'm glad you pulled off that save. Besides the house you could have severly burned your hands. A buddy's wife has insomnia and got out of bed at 1:30 AM and was doing some cooking. The pan containing the oil caught on fire and she tossed water on it to extinguish the flames. Naturally, the water vaporized immediately and sent flaming oil and thick smoke everywhere. She suffered third degree burns on one hand and her husband awoke and extinguished the fire and took her to the hospital. You're right about walking a fine line through life - you never know.
              Blessings,
              Chiz
                • 3114
                Ok, now I have to try that in the garage tonight.
                • jackellis
                  • 2638
                  • Tahoe City, CA, USA.
                  Great idea and going in the airplane's emergency kit. I have a big 24 volt battery under the cowl but I don't want to have to count on it.
                  • pierhogunn2
                    • Sep 2009
                    • 134
                    or for lots of fun cut the casing off of a model rocket motor, and put the solid propellant in a nest of steel wool. then take about 20' of 2 conductor wire and put that into the steel wool, to to the other end of your wire, and make contact with your 9V battery... whoosh... bye bye eye brows
                    damhikt
                    • Daryl
                      • 831
                      As a youth and the slot cars started to get boring, I would use steel wool for the contacts. I thought it added some realism.
                        YIKES! I'll bet that got your full attention! Glad all is well.
