Sorry to take so long to get back to you...we ended kinda busy at work yesterday afternoon but talked to my tech this am. Pretty bad job...we flag 4 hrs plus alignment for the labor.
What he does raise vehicle and block transmission bellhousing up...disconnect passenger side knuckle at ball joint and wire it forward as far as it will go. Then he pulls motor mount bolts out and loosens the six cradle to body bolts till the cradle is hanging by just a few threads on all 6 bolts to get enough room to get to the bolts and slip the whole bar out the side. He thinks its a little easier then pulling the whole strut out but still takes all of 4 hours.
If its any consolation the new sway bar design appears to be a permanent repair....before the redesign we could get just the bushings but they would just waller out again in a couple years.
Wow, Cody... That's gonna be a biatch! Thanks for the info, though. I guess tomorrow is gonna be a loooong day...
as there's still one bolt and a positioning tab that will be on there).
