I Don't Need Another Thing To Fix
    It got cold this weekend so I started the downstairs wood stove. My wife asked if I could start the one upstairs. We don't use it much - I don't think we used it all last winter. The fireplace was originally built for wood fires and has a damper. The wood stove is an insert type. I built a fire and it did not want to draft. I had the sweeps clean the chimney last fall. I think they left the damper in the fireplace closed. Now I will have to pull a large and very heavy wood stove to check.
    I hear ya, I had struts go out on my car, a pcb blow out with no schematics....., 3 plumbing jobs, and install new washer and dryer......
    ah, tomorrow it starts anew
      Just use the one downstairs., Hot air rises.
      • tkarlmann
        • 360
        • Hoffman Estates, IL, USA.
        Best thing I ever did ...
        ...was put one of those no-vent-required gas heaters in the shop. T-stat control too.
        Thom
          • 9503
          The most recent addition to my list... Replace the garbage disposal. Mine locked up tight as a drum last night.
          • Mr__Bill
            • 2096
            • Tacoma, WA
            I would take a mirror and check it for a measuring spoon trapped between the blade and wall............ I now have a set of bent up stainless spoons and I only took the #$%^ thing out once
            funny how the simple solution is obvious after doing it the hard way..
              • 9503
              Do tell... Like an auto inspection mirror?
              • Tom Slick
                • 2913
                • Paso Robles, Calif, USA.
                • sears BT3 clone
                don't forget to try the key in the bottom to free it up.
                • Kristofor
                  • 1331
                  • Twin Cities, MN
                  • Jet JTAS10 Cabinet Saw
                  You leave your flue damper open all of the time? Does the unit have it's own damper? Up here leaving a damper open for a month (when not in use) can add 30-50% to your heating bill...
                    The unit has its own damper. I have to leave the flue damper open. If I didn't I'd have to pull the stove out get to it each time I wanted to use the stove. At 400lbs+ that is not an easy job for this stove.
