If not for deed restrictions....
    ...that exclude mobile homes, I would be on the phone to find a mover. After all, the ad says it just "needs some TLC".
    http://austin.craigslist.org/zip/1466578794.html
    That has to be the understatement of the century, and the last one!
  • MilDoc
    TLC = "to light a conflagration"
    • Salty
      • 690
      • Akron, Ohio
      The first thing you would have to do is paint over the pink!
      EEEK!!
      T olulene
      L acquer thinner
      C ombustion
        What it really needs is some TTD (take to dump)...
          • 22025
          EEEK!!
          T olulene
          L acquer thinner
          C ombustion
          pink (eek) was my first thought, too.
          T.L.C.... LOL
            "Pink" is the least of the problems.
            • TB Roye
              • 2969
              • Sacramento, CA, USA.
              A little C4 or TNT might help move it. LOML worked as Housing Rep for the Calif. Dept of Housing. That might qualify for a Section 8 rental. I am not kidding I went with her a couple of times when she traveled to inspect so of the housing in the Rural Counties, beleive some weren't much better that that. That might qualify for Flip house though. Some of the Indian housing out here isn't much better especially out in hills, but that is a whole different story about choices.
              • jackellis
                • 2638
                • Tahoe City, CA, USA.
                Might make good firewood except for the fact that mobile homes use lots of materials that are laced with toxic chemicals.
                What would you do with this thing anyway?
                Dirty Jobs recently aired a segment on what it takes to prepare and move a double-wide mobile home that's been repossessed. I'll keep my day job, thanks.
                  Leave it right where it is....HIS PROBLEM!
                  • sparkeyjames
                    • 1087
                    • Redford MI.
                    If by TLC they mean...bring a bulldozer then I'm all for that definition.
                      I wonder if it even could be moved without falling apart. I also wonder if it is worth fixing. Mobile homes aren't worth that much and that one needs several thousand dollars of work.
                      • TB Roye
                        • 2969
                        If it didn't have all the hole is the exterior walls then it might make a good shop for someone with some property. Gut the inside and fix the bathroom and presto a long narrow shop. Looks like a 12 x 40 single wide. Naw TNT or C4 is still a better Idea or practice for firemen.
                        • Tom Slick
                          • 2913
                          • Paso Robles, Calif, USA.
                          • sears BT3 clone
                          need to get a hold of this guy
                          http://www.youtube.com/watch?v=q-RLqLx1iYI
