I don't know if anyone has posted about these yet, so I thought I would relate my experience with 2 'new' products I have tried.
First, the Rockler Bench Cookies.
Used them under a heavy door that I was applying poly to. The door is solid 100 year old doug fir, I believe. The word 'heavy' (about 65 lbs) might be key here. The door stuck to the waffled 'rubber' surface somewhat, although it didn't leave an impression on the poly. This was on poly that had dried for about 36 hours, and the Cookies were under the door for about 3-4 hours. Quite possibly would have left an impression if left longer.
To eliminate this, I put waxed paper over the waffling material, seems to work. I left the waffled surface alone on the bottom, so it grips the surface it is put on. The negative to this is that the piece you are working on is now more susceptible to move on the waxed paper, so you can't really horse anything around on the top of the project while using it this way.
second item is the Painters Pyramids.
Again, I think the weight and what you are doing on top is key. I used these under the same door as above, but this time i was sanding with a ROS. The pyramids dug noticeable holes into the door that had to be repaired.
I am not at all sure that if I was just painting the tops of the doors, no weight bearing, the results would have been any different, because they really did dig in.
These might be ok if the project was relatively light weight, but I would be reticent to try it again with any weight on it.
Anybody else have any experience with either of the above?
