BS gloat
  • jussi
    • 2162
    BS gloat
    Look what followed me home today. After missing out on 2 Ridgids for $130 I was psyched to find this one. It comes with an HTC mobile base as well. I notice the motor is only 1/2 HP while the Ridgids are 3/4. I hope this won't be a big deal. For the price I'll learn to live with it ... $99
    So what should I get next a new blade or a fence? If I go for the fence are there any recommendations? Or should I just clamp a piece of wood for now. I'd like to do some resawing. What's a good reasonably priced blade for that.
    http://orangecounty.craigslist.org/tls/1364922102.html
    You're not gonna do a lot of re-sawing with a 1/2hp motor, unfortunately. You'd spend the bulk of your time resetting your circuit breaker and/or prying a stuck blade out of your work.
    For good blades at excellent prices, and for a catalog full of bandsaw hop-up ideas, call Iturra Designs (1-888-722-7078).
      I've used two saws with 1/2-HP motors and 7" capacity for resaw, and they work fine w/ a good blade (for domestics I use the Blade Runner/WoodSlicer, and for exotics I use an MK Morse bimetal). It works fine. It isn't super fast, but I primarily resaw for stock to make small boxes, so I don't need a lot of material for any one project.
      • tommyt654
        • Nov 2008
        • 2334
        I agree with cg. As long as your not trying to push the boards thru like its a woodmizer the 1/2 h.p. will work fine.Do get a few good blades in varying sizes, a fence would be nice. You can still get the Kreg over at Hartville tools for about $100 shipped with the micro-adjuster. Good find.
        • toolguy1000
          • Mar 2009
          • 1142
          • westchester cnty, ny
          very good deal. certainly can't go too wrong with a delta. i'd start with a new blade first as that appears to be the most critical component of a bandsaw cut.
          uncle cracker... that's the third number i've seen for iturra, but it doen't work either. two rings and then open air and no one's there. do you have any other numbers?
            For the money you have in that, go through your local suppliers and find a deal on a 1.5HP motor and you'll have a heck of a saw for less than my HF cost me... If my tired eyes aren't lying to me, it looks like that is fitted with a riser block too...
            As far as blades go, Woodslicer, and Timberwolf are both excellent blades... I really like my TWs, they resaw great!
            As far as fences, avoid the Craftsman Professional universal. Pay a bit extra and grab a Kreg or something nice like that...
            • footprintsinconc
              • 1759
              • Roseville (Sacramento), CA
              here is a set of numbers that i used last year to order one. its a great blade. infact, it was for the exact same bandsaw that you just bought.
              Iturra Design
              4636 Fulton Rd
              Jacksonville, FL 32225
              866-883-8064
              904-642-2802
              904-371-3998 office
              check out these three threads with lots of info:
              http://www.bt3central.com/showthread...ghlight=Iturra
              omar
              • tseavoy
                • May 2009
                • 200
                • Nordland, Marrowstone Island, Washington
                • Older 9 inch Rockwell Delta (1960?)
                I've have and old Sears 12" bandsaw that I bought used in 1963 ($40). It has a 1/2 HP Dunlap (Sears or Montgomery Ward?) motor and I never thought I needed more power. Nowadays the only blade I use is a 1/2" 3TPI hook tooth blade. If I want to cut curves I use my Bosch saber saw.
                You got an excellent deal.
                Tom on Marrowstone
                • jussi
                  • 2162
                  Thanks for all the advice guys. I think I'll go with a decent resaw blade for my first purchase and will give Iturra a call.
                  I also need to add a new switch. Right now it's got a flimsy toggle switch that's not even attached to the saw. Will any paddle switch work?
                  Any tips on fine tuning it or what to look out for? Don't have too much experience with a bandsaw. I had a small Hitachi while back but never really used it and ended up selling it. I got a bunch of 4/4 and 6/4 rough lumber from CL and regretted getting rid of it.
                    I'd get the newer Duginske book. This one:
                    The link takes you to the books.google.com reader of text. But you can't read the entire thing online.
                    Has lots of helpful information.
                    Just this morning I was wondering why, whenever I put a 1/2" band on my saws, it tracks a little forward of center on my wheels. The 3/8" and 1/4" blades track dead center.
                    The book had the answer.
                      A great big +1 on Duginske's book. The man just flat knows his band saws. Do make sure you get the new edition (which shouldn't be a problem, as it has been out for a while now).
                      BTW, has anyone mentioned that YOU SUCK!? Besides me, I mean?
                      • footprintsinconc
                        • 1759
                        is this a tease?!? come on, tell us why too.
                        omar
                          On p. 76, he says:
                          "One of the things you will notice when you are using coplanar tracking is that the blade may track slightly toward the front of the wheels. This is because the front of the blade is minutely shorter than the back edge. When the blade was manufactured, the teeth were first ground and then hardened, causing the metal there to shrink in relationship to the unhardened back."
                          I'm not sure he's right. Blades are made from coils of stock which already have hardened teeth. So shrinkage would have already taken place, but the person welding the band would cut the band square and weld it square (we hope).
                          My theory: When tension is applied to a wide blade with a hardened front (teeth), the rear of the blade stretches more than the front. That causes the blade to track towards the front of the wheel.
                          I'm probably completely wrong. One of the resident engineers will likely straighten me out.
                          • toolguy1000
                            • Mar 2009
                            • 1142
                            footprintsinconc.. thanks for the numbers. last (office) number was a good one. person answering phone, who seemed to know a lot about everything bandsaw related, noted they disconnected all their toll free numbers. catalogue is on the way. they appear to be a great technical reference.
                              That Iturra catalog is thick with excellent info. People wait like vultures for them to come out every year. One printing, then you gotta wait till next year. The welds on their blades are as good, if not better, than blades costing 3X, and they're made from the same band stock, too.
