is it possible to replace the heat source in an RV, or a larger scale propane powered refrigerator with the heat from the focal point of a parabolic reflector that is 7' wide and get it to work?
the only reason that I ask, is that I figure I could use the projects old satellite dish to be the heat source, and unlike the normal intended momentary use for an RV refrigerator, just run this thing continuously for the 6 - 8 hours of full sun that we can get during the day here in Charlotte ( barring cloudy days)
The idea is that if this thing is running hard for 6 - 8 hours I could reduce the temperaure of a volume of water by an appreciable amount, hopefully something useful to cool the small volume of air in the www.ecobox.me home concept.
shoot, if there is enough heat to spare, I imagine that you could run 2 or 3 of these refrigeration units...
If I could find some more documentation on it, I would rather use a lithium bromide based absorption system, since it would use lower temps in the process, and you can use evacuated solar tubes which collect long-wave infrared even on cloudy days...
I just wish I knew what the math was to figure this out, and if I knew what that was, I wish I could actually do the math... ( I don't do math, I have nothing against it, I just stink at it)
LCHIEN
