Does anyone else do this?
    I'm a pretty active guy. Many times I find myself working around the house (inside or outside), and I might take my watch off, or take my glasses off (yes, I can see pretty well without them) if I'm working on something where they'll be in the way, get ruined, or just make things miserable for me.
    Here's the problem: I might be doing physical work when it's pretty hot outside, so I take my glasses off because the sweat just runs down into them, making them useless anyway. Or I'll set my knife down on a fence post or something because I'll need it again in a few minutes. There are any number of different scenarios that find me putting something where I shouldn't put it. Then I don't remember where I put it. Does anyone else have that problem? Age has nothing to do with it. Now where is my mouse?
  • pierhogunn
    • 1567
    • Harrisburg, NC, USA.
    um, yup, all the time.
    My FIL lost a $700 pair of some awful prescription super-de-duper advanced glasses...
    he is still looking for them, but I bet they are in a jacket pocket some where
    Monty Python's Flying Circus
    Dan in Harrisburg, NC
    • RodKirby
      • 3136
      • Mao Shan TSC-10RAS
      ALL the time!
      What was the question again
      Downunder ... 1" = 25.4mm
        • 2812
        Such a common problem and certainly one that I face all too often! Glasses, knife, screwdriver, whatever. The fact of the matter is that I know I'm not forgetful, crazy, or inattentive and in many, many cases, the lost item seems to end up being found, (almost magically) in a place that I know that I previously checked. Actually I excuse the problem as NOT mine, but one in which the "blue men" are at fault!
        Yep that's what I said, the "blue men".
        I recall quite a number of years ago, a "Twilight Zone" episode, in which the plot was about "Time" and the episode (IIRC) went something like the main character, misplaced something, started to leave the room and then abruptly turned around, coming back into the room... and there was this "surprised" blue man standing there with the misplaced tool in his hand (blue skin, overalls, etc.)
        The plot was that each frame of time was basically "set-up" by these "time workers". Each event/scene that we humans experienced was built by these blue men. Teams of them would spec out the existing time frame and then duplicate the next time frame so that we could "experience" it.
        Well, the episode went on to explain that occasionally somebody (one o the blue men) would slip up, forgetting to properly place an object in the next time frame, in which case the human would suddenly discover the object was missing. This could of course go on for several frames, until the "blue men" themselves discovered that they had missed placing it properly or not at all. In which case their supervisor would make the correction!
        (Actually, in real movie production there is a "continuity coordinator" who is responsible for making sure each scene filmed in a motion picture is properly setup and has all the props in place, from one picture shoot to another.)
        So, when these "lost" or "misplaced" items occur in my life, I don't fret too much about it as I know it's not me.... it's the "blue men"!
        ps, I should point out that if this happens too often (as it appears to be doing with me), you might want to duplicate some of those items that you most often loose. For example, I now have three sets of safety glasses, a dozen razer knives, and four tape measures!!! (I'm not sure four of the latter is enough though!).
          I do that all the time with tools at whatever jobsite I am working on. I solved the problem by trying to choose 'one spot' that I put my tools down unless I am using them. It mostly works.
          • scmhogg
            • 1839
            • Simi Valley, CA, USA.
            LOML and I believe in the saturation method. eg. If pens are a problem buy dozens until they are everywhere. I am pretty methodical with my glasses. Now the cell phone is another story. If it didn't ring, I would never find it.
            Steve
            • Thalermade
              • 791
              • Ohio
              • BT 3000
              Ed, I had to double check to make sure that I didn't write the original post.
              It is getting to the point that the only thing that I can easily remember is that I am very forgetful.
              My wedding ring has been found in many places around the house and garage.
              Tools can get lost in milliseconds, and I will not have moved a step!!
              I think there may be some truth to the "blue men".
              you are not alone
              Russ
              • jackellis
                • 2638
                • Tahoe City, CA, USA.
                You're not alone. I do it all the time and it can be terribly frustrating. My wife finally put her glasses on an elastic band so that she can let them hang from her neck when she doesn't need to wear them.
                In our house, the problem is even worse because we both tend to be messy and leave piles of things around.
                  When I lost my watch for 2 days, I thought I'd go nuts. Just didn't realize how often I look at it during the day. Where did I finally find it? In the linen closet on a shelf. I have no idea how it got there or why I took it off when I was near the linen closet.
                  • BobSch
                    • 4385
                    Well, I don't have a problem with my glasses, since I can't see past my nose without them. Now tools...
                    Bob
                      Russ
                      That is found at YOUR house and garage?
                      Glasses on the forehead, when I am reading up close (blind at a distance, and like the Dr.'s that perform lasiks, I haven't had it.
                      Glasses on the nightstand, and not there the next day (knocked off, and afraid to step on them), or left at the computer.
                      Tools set down, when the phone rings, or mother nature calls.
                      Not to mention, I think I have lost my mind a few times.
                      • Alex Franke
                        • Feb 2007
                        • 2641
                        • Chapel Hill, NC
                        Once after having lost the television remote control for nearly a week, it finally turned up in the back of the freezer.
                          I never have that problem....
                          ....when I'm alseep! During the waking hours is another story (or several a day!)
                          • cobob
                            • 252
                            • Rolla, MO, USA.
                            Aw shucks; most recently, I can't find my grease gun. I keep asking myself, "How can you lose a grease gun?!" I've looked everywhere twice. It's not in any shirt or jacket pocket.
                            • BerniePA
                              • 377
                              • San Tan Valley, AZ
                              • Grizzly 0575
                              Well I don't think that.......
                              What problem were you fellas sayin' you were havin' again??
                              Bernie
