If I'm looking at having to add 4", that would probably put me in the 10-11 yard range. Looks like building a frame and decking it may be the best solution. One advantage to it is that I can do 1/2 at a time and just move stuff around.
Going rate for concrete
That's nothing to worry about with your concrete block exterior walls. Slabs, even thick ones, are poured every day with far less substantial formwork to contain the wet concrete.
I agree that the area where only a thin topping slab is needed will be problematic. You'd want to use a high-strength concrete and ensure that it bonds well to the existing slab. It can be done, but it's dicey.
If there is a possibility, however remote or distant, of someday tearing the building down and building anew, that might be another reason to go with wood. A wooden superstructure could be torn out and the materials reused for something, whereas concrete will just have to be jack-hammered up and carted to the landfill.LarryComment
There's other options than using standard concrete, especially in the 2" areas. There are a verity of lightweight mixes we use for subfloors, sometimes as the finished floor with burnishing & staining. Most of it going on top of wood framing.
We've been looking into USG's Levelrock too. It's a gypsum product like gyp-crete. Our office had a lunch & learn last week and took a good look at some of their new stuff. They've got a new high PSI 1/4" topping that comes in several colors.ErikComment
I priced 2.75 cubic yards today for delivery next week. Here in Jonesboro it will run
$289.06 tax and all. It is for a slab in a storage building, 12' X 18'. Bill5 OUT OF 4 PEOPLE DON'T UNDERSTAND FRACTIONS.Comment
