Did you know that Starett makes bandsaw blades?
    And they are a lot cheaper and of better quality than timberwolf blades. Also, did you know that bandsaw blades are also available with carbide teeth with no set, just atb! Some curious info I have picked up here in Tennessee while visiting Lonnie Bird's woodworking school (stealth gloat) Day 3 just finished and my shaker style night table carcass is complete. Spent the entire day practicing dovetails in anticipation of creating the drawer for the table tomorrow.
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    Yes to all of the above. I've used them at work, we bought standard bimetal band by the roll and welded them up. We bought carbide resawing bands pre-made, they were 1" wide by 19' 6" long and cost about $300 ea.
    I've also used sandvik band material.
    • Stytooner
      Roll Tide RIP Lee
      • 4301
      • Robertsdale, AL, USA.
      I've used Starett bimetal blades for years now. I use them on both my metal bandsaw and my 10" Craftsman. I get them from McMaster Carr. They work great. I have a 1" blade on my HF 14" for resawing, but it isn't a Starett. I need to get one on there sometime.
      Cool stealth gloat as well.
        • 22033
        carbide blades for a BS are nice but they can get kinda pricey.
        OTOH, not really more unreasonable blade$/saw$ ratio than a $100 Forrest blade on my $300-400 (original cost) BT3000.
          I use Lennox 3/4" 3 tpi bi-metal for re-saw on my Steel City 18" and can't say enough about how good they are. Cost around $48 welded and shipped and last about 1/3 the time of a carbide blade. So... I can buy 5 of them for the price of one carbide for my saw and come out well ahead on blades dulling.
          But... it needs to be noted that carbide requires a ton of tension.. bi-metal requires a little less so... anyone with a smaller BS that is equipped with less than heavy tension spring... Beware as you might not be able to tension the bi-metal or carbide properly.
          I might try one of the Starrett's from McMaster Carr Lee mentioned. How much are you paying shipped Lee and... what lenght?
          • Stytooner
            Roll Tide RIP Lee
            • 4301
            This is the one on my metal bandsaw.
            http://www.mcmaster.com/#catalog/115/2339/=1kis2t
            Type
            Blades for Thin Metals
            Material
            Bimetal
            Tooth Style
            Standard
            Teeth Per Inch (Standard)
            18
            Width
            1/2"
            Length
            5' 4-1/2"
            Thickness
            0.025"
            This one on my Craftsman.
            http://www.mcmaster.com/#catalog/115/2338/=1kisjz
            Type
            Blades for Hard Metals
            Material
            Bimetal
            Tooth Style
            Anti-Vibration
            Teeth Per Inch (Anti-Vibration)
            10-14
            Width
            3/8"
            Length
            5' 10-1/2"
            Thickness
            0.025"
            These cost about $24 each. Mcmaster is very reasonable on shipping. $5 or $6 bucks I think for a small box.
            Surely you can find something else they sell that you need to help fill the box up.
            I have no problem finding stuff I need.
            • GregW
              • 17
              If you have a McMaster Carr location local to you they also have a very organized and efficient will call system that I've used many times in the past...
                I would probably order two as I usually do. I prefer back-up blades on-hand as nothing is more irratating than for a blade to go dull just when you are intend to re-saw a couple of hundred linear feet. Same with rip blades on my TS... I have 4 and 4 40 T's even though my sharpener is 4 miles away and can turn a blade in 2 days when bush and one when not.
                Thanks Lee as I might order one if they have 3 tpi to try it out.
                Sarge..
                • tommyt654
                  • Nov 2008
                  • 2334
                  www.lagunatools.com has their 5/8 inch resaw blades on sale B1G1 on their website under accessories I ordered 2 93 1/2 for $28.05 + shipping, great price. Tell em I sent ya,Tommy
                    To point out one thing that made me take note of why we would use a carbide blade...... the one thing it can do that no other bandsaw blade can do - - - > save wood - thin kerf, the teeth have no set, rather just an alternating bevel. I guess that would be important if you are resawing very expensive wood.
